--- 产品详情 ---
Number of channels (#) | 2 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 32 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 3 |
Rail-to-rail | In to V- |
GBW (Typ) (MHz) | 0.9 |
Slew rate (Typ) (V/us) | 0.4 |
Vos (offset voltage @ 25 C) (Max) (mV) | 3 |
Iq per channel (Typ) (mA) | 0.35 |
Vn at 1 kHz (Typ) (nV/rtHz) | 50 |
Rating | Catalog |
Operating temperature range (C) | -40 to 105 |
Offset drift (Typ) (uV/C) | 7 |
Features | Internal reference |
Input bias current (Max) (pA) | 150000 |
CMRR (Typ) (dB) | 85 |
Output current (Typ) (mA) | 12 |
Architecture | Bipolar |
- Operational Amplifier
- Low Offset Voltage Max of:
- TL103WA…3 mV (25°C) and 5 mV (Full?Temperature)
- TL103W…4 mV (25°C) and 5 mV (Full?Temperature)
- Low Supply Current…350?μA/Channel?(Typ)
- Unity Gain Bandwidth…0.9 MHz (Typ)
- Input Common-Mode Range Includes GND
- Large Output-Voltage Swing… 0 V to VCC?– 1.5 V
- Wide Supply-Voltage Range…3 V to 32 V
- 2.5-kV ESD Protection (HBM)
- Voltage Reference
- Fixed 2.5-V Reference
- Tight Tolerance Max of:
- TL103WA…0.4% (25°C) and 0.8% (Full?Temperature)
- TL103W . . . 0.7% (25°C) and 1.4% (Full?Temperature)
- Low Temperature Drift…7 mV (Typ) Over Operating Temperature Range
- Wide Sink-Current Range . . . 0.5 mA (Typ) to 100 mA
- Output Impedance…0.2 Ω (Typ)
- APPLICATIONS
- Battery Chargers
- Switch-Mode Power Supplies
- Linear Voltage Regulation
- Data-Acquisition Systems
All other trademarks are the property of their respective owners
The TL103W and TL103WA combine the building blocks of a dual operational amplifier and a fixed voltage reference – both of which often are used in the control circuitry of both switch-mode and linear power supplies. OP AMP1 has its noninverting input internally tied to a fixed 2.5-V reference, while OP AMP2 is independent, with both inputs uncommitted.
For the A grade, especially tight voltage regulation can be achieved through low offset voltages for both operational amplifiers (typically 0.5?mV) and tight tolerances for the voltage reference (0.4% at 25°C and 0.8% over operating temperature range).
The TL103W and TL103WA are characterized for operation from –40°C to 105°C.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
