--- 产品详情 ---
Architecture | Voltage FB |
Number of channels (#) | 1 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 5 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 12 |
GBW (Typ) (MHz) | 1000 |
BW @ Acl (MHz) | 260 |
Acl, min spec gain (V/V) | 4 |
Slew rate (Typ) (V/us) | 1400 |
Vn at flatband (Typ) (nV/rtHz) | 4.1 |
Vn at 1 kHz (Typ) (nV/rtHz) | 13 |
Iq per channel (Typ) (mA) | 15.5 |
Vos (offset voltage @ 25 C) (Max) (mV) | 5 |
Rail-to-rail | No |
Features | Integrated Clamps, Decompensated |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
CMRR (Typ) (dB) | 61 |
Input bias current (Max) (pA) | 10000000 |
Offset drift (Typ) (uV/C) | 15 |
Output current (Typ) (mA) | 120 |
2nd harmonic (dBc) | 67 |
3rd harmonic (dBc) | 87 |
Frequency of harmonic distortion measurement (MHz) | 5 |
- HIGH LINEARITY NEAR LIMITING
- FAST RECOVERY FROM OVERDRIVE: 1ns
- LIMITING VOLTAGE ACCURACY: ±10mV
- –3dB BANDWIDTH (G = +6): 260MHz
- GAIN BANDWIDTH PRODUCT: 1000MHz
- STABLE FOR G +4V/V
- SLEW RATE: 1400V/μs
- ±5V AND +5V SUPPLY OPERATION
- LOW GAIN VERSION: OPA698
- APPLICATIONS
- TRANSIMPEDANCE WITH FAST OVERDRIVE RECOVERY
- FAST LIMITING ADC INPUT DRIVER
- LOW PROP DELAY COMPARATOR
- NONLINEAR ANALOG SIGNAL PROCESSING
- DIFFERENCE AMPLIFIER
- IF LIMITING AMPLIFIER
- OPA689 UPGRADE
All trademarks are the property of their respective owners.
The OPA699 is a wideband, voltage-feedback op amp that offers bipolar output voltage limiting, and is stable for gains +4. Two buffered limiting voltages take control of the output when it attempts to drive beyond these limits. This new output limiting architecture holds the limiter offset error to ±10mV. The op amp operates linearly to within 20mV of the limits.
The combination of narrow nonlinear range and low limiting offset allows the limiting voltages to be set within 100mV of the desired linear output range. A fast 1ns recovery from limiting ensures that overdrive signals will be transparent to the signal channel. Implementing the limiting function at the output, as opposed to the input, gives the specified limiting accuracy for any gain, and allows the OPA699 to be used in all standard op amp applications.
Nonlinear analog signal processing circuits will benefit from the OPA699 sharp transition from linear operation to output limiting. The quick recovery time supports high-speed applications.
The OPA699 is available in an industry-standard pinout in an SO-8 package. For lower gain applications requiring output limiting with fast recovery, consider the OPA698.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
