--- 产品详情 ---
Architecture | Current FB |
Number of channels (#) | 2 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 10 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 30 |
GBW (Typ) (MHz) | 110 |
BW @ Acl (MHz) | 110 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 1550 |
Vn at flatband (Typ) (nV/rtHz) | 2.8 |
Vn at 1 kHz (Typ) (nV/rtHz) | 2.2 |
Iq per channel (Typ) (mA) | 4.9 |
Vos (offset voltage @ 25 C) (Max) (mV) | 10 |
Rail-to-rail | No |
Features | Shutdown |
Rating | Catalog |
Operating temperature range (C) | -40 to 85, 0 to 70 |
CMRR (Typ) (dB) | 67 |
Input bias current (Max) (pA) | 2000000 |
Offset drift (Typ) (uV/C) | 10 |
Output current (Typ) (mA) | 270 |
2nd harmonic (dBc) | 78 |
3rd harmonic (dBc) | 78 |
Frequency of harmonic distortion measurement (MHz) | 1 |
- Low Noise:
- 2.9-pA/√Hz Noninverting Current Noise
- 10.8-pA/√Hz Inverting Current Noise
- 2.2-nV/√Hz Voltage Noise
- Wide Supply Voltage Range: ±5 V to ± 15 V
- Wide Output Swing:
- 25-VPP Output Voltage, RL = 100
, ±15-V Supply
- High Output Current: 150 mA (Min)
- High Speed:
- 110-MHz (–3-dB BW, G = 1, ±15 V)
- 1550-V/μs Slew Rate (G = 2, ±15 V)
- Low Distortion (G = 2):
- –78 dBc (1 MHz, 2 VPP, 100-
Load)
- Low-Power Shutdown (THS3115)
- 300-μA Shutdown Quiescent Current per Channel
- Standard SOIC, SOIC PowerPAD?, and TSSOP PowerPAD Packages
- Evaluation Module Available
- APPLICATIONS
- Communication Equipment
- Video Distribution
- Motor Drivers
- Piezo Drivers
PowerPAD Is a trademark of Texas Instruments.
All other trademarks are the property of their respective owners.
The THS3112/5 are low-noise, high-speed current feedback amplifiers, ideal for any application requiring high output current. The low noninverting current noise of 2.9 pA/√Hz and the low inverting current noise of 10.8pA/√Hz increase signal-to-noise ratios for enhanced signal resolution. The THS3112/5 can operate from ±5-V to ±15-V supply voltages, while drawing as little as 4.5 mA of supply current per channel. It offers low –78-dBc total harmonic distortion driving 2 VPP into a 100- load. The THS3115 features a low-power shutdown mode, consuming only 300-μA shutdown quiescent current per channel. The THS3112/5 are packaged in standard SOIC, SOIC PowerPAD?, and TSSOP PowerPAD packages.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
