--- 产品详情 ---
Architecture | Voltage FB |
Number of channels (#) | 1 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 10 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 30 |
GBW (Typ) (MHz) | 200 |
BW @ Acl (MHz) | 200 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 100 |
Vn at flatband (Typ) (nV/rtHz) | 1.6 |
Vn at 1 kHz (Typ) (nV/rtHz) | 1.6 |
Iq per channel (Typ) (mA) | 8.5 |
Vos (offset voltage @ 25 C) (Max) (mV) | 2 |
Rail-to-rail | No |
Rating | Military |
Operating temperature range (C) | -55 to 125 |
CMRR (Typ) (dB) | 95 |
Input bias current (Max) (pA) | 6000000 |
Offset drift (Typ) (uV/C) | 2 |
Output current (Typ) (mA) | 90 |
2nd harmonic (dBc) | 81 |
3rd harmonic (dBc) | 81 |
Frequency of harmonic distortion measurement (MHz) | 1 |
- Ultralow 1.6-nV/
Hz Voltage Noise
- High Speed:
- 100-MHz Bandwidth [G = 2 (-1), –3 dB]
- 100-V/μs Slew Rate
- Very Low Distortion
- THD = –72 dBc (f = 1 MHz, RL = 150
- THD = –90 dBc (f = 1 MHz, RL = 1 k
- Low 0.5-mV (Typ) Input Offset Voltage
- 90-mA Output Current Drive (Typical)
- ±5 V to ±15 V Typical Operation
- Available in Standard SOIC, MSOP PowerPAD?, JG, or FK Package
- Evaluation Module Available
- SUPPORTS DEFENSE, AEROSPACE, AND MEDICAL APPLICATIONS
- Controlled Baseline
- One Assembly/Test Site
- One Fabrication Site
- Available in Military (–55°C/125°C) Temperature Range(1)
- Extended Product Life Cycle
- Extended Product-Change Notification
- Product Traceability
(1) Additional temperature ranges are available - contact factory
PowerPAD is a trademark of Texas Instruments.
The THS4031 and THS4032 are ultralow-voltage noise, high-speed voltage feedback amplifiers that are ideal for applications requiring low voltage noise, including communications and imaging. The single amplifier THS4031 and the dual amplifier THS4032 offer very good ac performance with 100-MHz bandwidth (G = 2), 100-V/μs slew rate, and 60-ns settling time (0.1%). The THS4031 and THS4032 are unity gain stable with 275-MHz bandwidth. These amplifiers have a high drive capability of 90 mA and draw only 8.5-mA supply current per channel. With ?90 dBc of total harmonic distortion (THD) at f = 1 MHz and a very low noise of 1.6 nV/Hz, the THS4031 and THS4032 are ideally suited for applications requiring low distortion and low noise such as buffering analog-to-digital converters.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
