--- 产品详情 ---
Number of channels (#) | 4 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 44 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 5 |
Vos (offset voltage @ 25 C) (Max) (mV) | 0.3 |
GBW (Typ) (MHz) | 0.7 |
Slew rate (Typ) (V/us) | 0.4 |
Rail-to-rail | In to V- |
Offset drift (Typ) (uV/C) | 0.4 |
Iq per channel (Typ) (mA) | 0.35 |
Vn at 1 kHz (Typ) (nV/rtHz) | 22 |
CMRR (Typ) (dB) | 117 |
Rating | Catalog |
Operating temperature range (C) | 0 to 70 |
Input bias current (Max) (pA) | 30000 |
Output current (Typ) (mA) | 25 |
Architecture | Bipolar |
- Single-Supply Operation:
Input Voltage Range Extends to Ground, and
Output Swings to Ground While Sinking Current - Input Offset Voltage 300 μV Max at 25°C for LT1014
- Offset Voltage Temperature Coefficient
2.5 μV/°C Max for LT1014 - Input Offset Current 1.5 nA Max at 25°C for LT1014
- High Gain 1.2 V/μV Min (RL = 2 k), 0.5 V/μV
Min (RL = 600 ) for LT1014 - Low Supply Current 2.2 mA Max at 25°C for LT 1014
- Low Peak-to-Peak Noise Voltage 0.55 μV Typ
- Low Current Noise 0.07 pA/Hz Typ
The LT1014, LT1014A, and LT1014D are quad precision operational amplifiers with 14-pin industry-standard configuration. They feature low offset-voltage temperature coefficient, high gain, low supply current, and low noise.
The LT1014, LT1014A, and LT1014D can be operated with both dual ±15-V and single 5-V power supplies. The common-mode input voltage range includes ground, and the output voltage can also swing to within a few milivolts of ground. Crossover distortion is eliminated.
The LT1014C and LT1014D are characterized for operation from 0°C to 70°C. The LT1014I and LT1014DI are characterized for operation from ?40°C to 105°C. The LT1014M, LT1014AM and LT1014DM are characterized for operation over the full military temperature range of ?55°C to 125°C.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
