--- 产品详情 ---
Number of channels (#) | 2 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 15 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 5 |
Rail-to-rail | In to V-, Out |
GBW (Typ) (MHz) | 0.35 |
Slew rate (Typ) (V/us) | 0.11 |
Vos (offset voltage @ 25 C) (Max) (mV) | 3 |
Iq per channel (Typ) (mA) | 0.043 |
Vn at 1 kHz (Typ) (nV/rtHz) | 42 |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
Offset drift (Typ) (uV/C) | 1.3 |
Input bias current (Max) (pA) | 4 |
CMRR (Typ) (dB) | 83 |
Output current (Typ) (mA) | 21 |
Architecture | CMOS |
Rail-to-rail output swing | ? |
Micropower operation (<0.5 mW) | ? |
Specified for 100 k and 5 k loads | ? |
High voltage gain | 120 dB |
Low input offset voltage | 3 mV |
Low offset voltage drift | 1.3 μV/°C |
Ultra low input bias current | 2 fA |
Input common-mode includes GND | ? |
Operating range from +5V to +15V | ? |
Low distortion | 0.01% at 1 kHz |
Slew rate | 0.11 V/μs |
Full military temperature range available | ? |
The LPC662 CMOS Dual operational amplifier is ideal for operation from a single supply. It features a wide range of operating voltage from +5V to +15V, rail-to-rail output swing in addition to an input common-mode range that includes ground. Performance limitations that have plagued CMOS amplifiers in the past are not a problem with this design. Input VOS, drift, and broadband noise as well as voltage gain (into 100 k and 5 k) are all equal to or better than widely accepted bipolar equivalents, while the power supply requirement is typically less than 0.5 mW.
This chip is built with National's advanced Double-Poly Silicon-Gate CMOS process.
See the LPC660 datasheet for a Quad CMOS operational amplifier and LPC661 for a single CMOS operational amplifier with these same features.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
