--- 产品详情 ---
Quad, 32-V, 100-kHz, low Iq (21-μA/ch) op amp with 0°C to 70°C operation
Number of channels (#) | 4 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 32 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 3 |
Rail-to-rail | In to V- |
GBW (Typ) (MHz) | 0.1 |
Slew rate (Typ) (V/us) | 0.05 |
Vos (offset voltage @ 25 C) (Max) (mV) | 9 |
Iq per channel (Typ) (mA) | 0.02125 |
Vn at 1 kHz (Typ) (nV/rtHz) | 80 |
Rating | Catalog |
Operating temperature range (C) | 0 to 70 |
Offset drift (Typ) (uV/C) | 10 |
Input bias current (Max) (pA) | 10000 |
CMRR (Typ) (dB) | 90 |
Output current (Typ) (mA) | 4 |
Architecture | Bipolar |
- Low Supply Current:?85μA (typ)
- Low Offset Voltage:?2mV (typ)
- Low Input Bias Current:?2nA (typ)
- Input Vommon Mode to GND
- Interfaces to CMOS Logic
- Wide Supply Range:?3V < V+ < 32V
- Small Outline Package Available
- Pin-for-pin Compatible with LM324
All trademarks are the property of their respective owners.
The LP324-N series consists of four independent, high gain internally compensated micropower operational amplifiers. These amplifiers are specially suited for operation in battery systems while maintaining good input specifications, and extremely low supply current drain. In addition, the LP324-N has an input common mode range, and output source range which includes ground, making it ideal in single supply applications.
These amplifiers are ideal in applications which include portable instrumentation, battery backup equipment, and other circuits which require good DC performance and low supply current.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
