--- 产品详情 ---
Number of channels (#) | 2 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 36 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 7 |
Rail-to-rail | No |
GBW (Typ) (MHz) | 4 |
Slew rate (Typ) (V/us) | 15 |
Vos (offset voltage @ 25 C) (Max) (mV) | 3 |
Iq per channel (Typ) (mA) | 1.8 |
Vn at 1 kHz (Typ) (nV/rtHz) | 25 |
Rating | Military |
Operating temperature range (C) | -55 to 125 |
Offset drift (Typ) (uV/C) | 7 |
CMRR (Typ) (dB) | 100 |
Output current (Typ) (mA) | 25 |
Architecture | FET |
- Input Offset Voltage Drift: 20 μV/°C (Max)
- Low Input Bias Current: 50 pA (Typ)
- Low Input Noise Current: 0.01 pA/√Hz (Typ)
- Wide Gain Bandwidth: 2.7 MHz (Min)
- High Slew Rate: 8V/μs (Min)
- High Input Impedance: 1012Ω
- Low Total Harmonic Distortion <0.02%
- Low 1/f Noise Corner: 50 Hz
- Fast Settling Time to 0.01%: 2 μs
All trademarks are the property of their respective owners.
This device is a low cost, high speed, JFET input operational amplifier with very low input offset voltage and ensured input offset voltage drift. It requires low supply current yet maintains a large gain bandwidth product and fast slew rate. In addition, well matched high voltage JFET input devices provide very low input bias and offset currents. The LF412 dual is pin compatible with the LM1558, allowing designers to immediately upgrade the overall performance of existing designs.
This amplifier may be used in applications such as high speed integrators, fast D/A converters, sample and hold circuits and many other circuits requiring low input offset voltage and drift, low input bias current, high input impedance, high slew rate and wide bandwidth.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
