--- 产品详情 ---
+-200V 共模电压差动放大器
Number of channels (#) | 1 |
Vs (Min) (V) | 2.7 |
Vs (Max) (V) | 36 |
CMRR (Min) (dB) | 70 |
Common mode input low (Min) (V) | -200 |
Common mode input high (Max) (V) | 200 |
Input offset (+/-) (Max) (uV) | 5000 |
Iq (Typ) (mA) | 0.6 |
Small signal bandwidth (Typ) (MHz) | 0.1 |
Slew rate (Typ) (V/us) | 1 |
Gain (Min) (V/V) | 1 |
Gain (Max) (V/V) | 1 |
Gain error (+/-) (Max) (%) | 0.075 |
Rating | Catalog |
Operating temperature range (C) | -55 to 125 |
Gain drift (Max) (ppm/C) | 3 |
- LOW NONLINEARITY: 0.002% max
- HIGH COMMON-MODE VOLTAGE:
- +75V at VS = +5V
- ±200V at VS = ±15V
- FIXED DIFFERENTIAL GAIN = 1V/V
- LOW QUIESCENT CURRENT: 260μA
- WIDE SUPPLY RANGE:
- Single Supply: 2.7V to 36V
- Dual Supplies: ±1.35V to ±18V
- LOW GAIN ERROR: 0.075% max
- HIGH CMR: 86dB
- SO-8 PACKAGE
The INA148 is a precision, low-power, unity-gain difference amplifier with a high common-mode input voltage range. It consists of a monolithic precision bipolar op amp with a thin-film resistor network.
The on-chip resistors are laser trimmed for an accurate 1V/V differential gain and high common-mode rejection. Excellent temperature tracking of the resistor network maintains high gain accuracy and common-mode rejection over temperature. The INA148 will operate on single or dual supplies.
The INA148 is available in a small SO-8 surface-mount package and it is specified for the ?40°C to +85°C extended industrial temperature range.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
