--- 产品详情 ---
Number of channels (#) | 1 |
Vs (Min) (V) | 2.76 |
Vs (Max) (V) | 36 |
CMRR (Min) (dB) | 76 |
Common mode input low (Min) (V) | -100 |
Common mode input high (Max) (V) | 100 |
Input offset (+/-) (Max) (uV) | 5000 |
Iq (Typ) (mA) | 0.6 |
Small signal bandwidth (Typ) (MHz) | 0.5 |
Slew rate (Typ) (V/us) | 0.45 |
Gain (Min) (V/V) | 0.1 |
Gain (Max) (V/V) | 100 |
Gain error (+/-) (Max) (%) | 0.1 |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
Gain drift (Max) (ppm/C) | 1 |
- HIGH COMMON-MODE VOLTAGE:
- +40V at V S = +5V
- ±100V at V S = ±15V
- DIFFERENTIAL GAIN = 0.1V/V TO 100V/V:
- Set with External Resistors
- LOW QUIESCENT CURRENT: 570μA
- WIDE SUPPLY RANGE:
- Single Supply: 4.5V to 36V
- Dual Supplies: ±2.25V to ±18V
- LOW GAIN ERROR: 0.025%
- HIGH CMR: 80dB
- SO-8 PACKAGE
The INA146 is a precision difference amplifier that can be used to accurately attenuate high differential voltages and reject high common-mode voltages for compatibility with common signal processing voltage levels. High-voltage capability also affords inherent input protection. The input common-mode range ex-tends beyond both supply rails, making the INA146 well-suited for both single and dual supply applica-tions.
On-chip precision resistors are laser-trimmed to achieve accurate gain and high common-mode rejection. Ex-cellent TCR tracking of these resistors assures contin-ued high precision over temperature.
A 10:1 difference amplifier provides 0.1V/V gain when the output amplifier is used as a unity-gain buffer. In this configuration, input voltages up to ±100V can be measured. Gains greater than 0.1V/V can be set with an external resistor pair without affect-ing the common-mode input range.
The INA146 is available in the SO-8 surface-mount package specified for the extended industrial tempera-ture range, -40°C to +85°C.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
