--- 产品详情 ---
1.8GHz 宽带固定增益放大器
Architecture | Fixed Gain/Buffer |
Number of channels (#) | 1 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 3 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 5 |
GBW (Typ) (MHz) | 1800 |
BW @ Acl (MHz) | 1800 |
Acl, min spec gain (V/V) | 10 |
Slew rate (Typ) (V/us) | 5500 |
Vn at flatband (Typ) (nV/rtHz) | 2.8 |
Vn at 1 kHz (Typ) (nV/rtHz) | 18 |
Iq per channel (Typ) (mA) | 34 |
Vos (offset voltage @ 25 C) (Max) (mV) | 4.25 |
Rail-to-rail | No |
Features | Shutdown |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
CMRR (Typ) (dB) | 60 |
Input bias current (Max) (pA) | 1000000 |
Offset drift (Typ) (uV/C) | 20 |
Output current (Typ) (mA) | 180 |
2nd harmonic (dBc) | 65 |
3rd harmonic (dBc) | 76 |
Frequency of harmonic distortion measurement (MHz) | 70 |
- Fixed Closed-Loop Gain Amplifier
- 10 V/V (20 dB)
- Wide Bandwidth: 1.8 GHz
- High Slew Rate: 5500 V/μs
- Low Total Input Referred Noise: 2.5 nV/Hz
- Low Distortion
- HD2: –65 dBc at 70 MHz
- HD3: –76 dBc at 70 MHz
- IMD3: –85 dBc at 100 MHz
- OIP3: 34 dBm at 100 MHz
- IMD3: –70 dBc at 300 MHz
- OIP3: 27 dBm at 300 MHz
- High Output Drive: ±180 mA
- Power Supply Voltage: 3 V or 5 V
- APPLICATIONS
- Wideband Signal Processing
- Wireless Transceivers
- IF Amplifier
- ADC Preamplifier
- DAC Output Buffers
- Test, Measurement, and Instrumentation
- Medical and Industrial Imaging
PowerPAD is a trademark of Texas Instruments.
The THS4303 device is a wideband, fixed-gain amplifier that offers high bandwidth, high slew rate, low noise, and low distortion. This combination of specifications enables analog designers to transcend current performance limitations and process analog signals at much higher speeds than previously possible with closed-loop, complementary amplifier designs. The devices are offered in a 16-pin leadless package and incorporate a powerdown mode for quiescent power savings.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
