--- 产品详情 ---
Number of channels (#) | 2 |
Architecture | DSL Line Driver, PLC Line Driver |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 8 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 33 |
BW @ Acl (MHz) | 100 |
Acl, min spec gain (V/V) | 1 |
Vn at flatband (Typ) (nV/rtHz) | 3.2 |
Vn at 1 kHz (Typ) (nV/rtHz) | 13 |
Iq per channel (Typ) (mA) | 11.5 |
Vos (offset voltage @ 25 C) (Max) (mV) | 20 |
Rail-to-rail | No |
Features | Shutdown, Adjustable BW/IQ/IOUT |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
CMRR (Typ) (dB) | 54 |
Input bias current (Max) (pA) | 15000000 |
Offset drift (Typ) (uV/C) | 50 |
GBW (Typ) (MHz) | 100 |
Output current (Typ) (mA) | 600 |
2nd harmonic (dBc) | 88 |
3rd harmonic (dBc) | 107 |
Frequency of harmonic distortion measurement (MHz) | 1 |
- Low-Power Dissipation Increases ADSL Line Card Density
- Low THD of -88 dBc (100 , 1 MHz)
- Low MTPR Driving +20 dBm on the Line
- -76 dBc With High Bias Setting
- -74 dBc With Low Bias Setting
- Wide Output Swing of 44 VPP Differential Into a 200- Differential Load (VCC = ±12 V)
- High Output Current of 600 mA (Typ)
- Wide Supply Voltage Range of ±5 V to ±15 V
- Pin Compatible with EL1503C and EL1508C
- Multiple Package Options
- Multiple Power Control Modes
- 11 mA/ch Full Bias Mode
- 7.5 mA/ch Mid Bias Mode
- 4 mA/ch Low Bias Mode
- 0.25 mA/ch Shutdown Mode
- IADJ Pin for User Controlled Bias Current
- Stable Operation Down to 1.8 mA/ch
- Low Noise for Increased Receiver Sensitivity
- 3.2 nV/Hz Inverting Current Noise
- APPLICATIONS
- Ideal for Full Rate ADSL Applications
PowerPAD is a trademark of Texas Instruments.
The THS6182 is a current feedback differential line driver ideal for full rate ADSL systems. Its extremely low-power dissipation is ideal for ADSL systems that must achieve high densities in ADSL central office rack applications. The unique architecture of the THS6182 allows the quiescent current to be much lower than existing line drivers while still achieving high linearity without the need for excess open loop gain. Fixed multiple bias settings of the amplifiers allow for enhanced power savings for line lengths where the full performance of the amplifier is not required. To allow for even more flexibility and power savings, an IADJ pin is available to further lower the bias currents while maintaining stable operation with as little as 1.8 mA per channel. The wide output swing of 44 VPP differentially with ±12-V power supplies allows for more dynamic headroom, keeping distortion at a minimum. With a low 3.2 nV/Hz inverting current noise, the THS6182 increases the sensitivity of the receive signals, allowing for better margins and reach.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
