--- 产品详情 ---
Architecture | Fixed Gain/Buffer |
Number of channels (#) | 1 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 3 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 10 |
GBW (Typ) (MHz) | 1750 |
BW @ Acl (MHz) | 1750 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 4580 |
Vn at flatband (Typ) (nV/rtHz) | 3.9 |
Vn at 1 kHz (Typ) (nV/rtHz) | 13 |
Iq per channel (Typ) (mA) | 10 |
Vos (offset voltage @ 25 C) (Max) (mV) | 1 |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
Output current (Typ) (mA) | 74 |
2nd harmonic (dBc) | 58 |
3rd harmonic (dBc) | 53 |
Frequency of harmonic distortion measurement (MHz) | 20 |
- Closed-Loop Buffer
- 1750MHz Small Signal Bandwidth
- 4580V/μs Slew Rate
- 0.06% / 0.02° Differential Gain/Phase
- ?52dBc THD at 20MHz
- Single Supply Operation (3V Min.)
- 75mA Output Current
All trademarks are the property of their respective owners.
The LMH6559 is a high-speed, closed-loop buffer designed for applications requiring the processing of very high frequency signals. While offering a small signal bandwidth of 1750MHz, and an ultra high slew rate of 4580V/μs the LMH6559 consumes only 10mA of quiescent current. Total harmonic distortion into a load of 100? at 20MHz is ?52dBc. The LMH6559 is configured internally for a loop gain of one. Input resistance is 200k? and output resistance is but 1.2?. These characteristics make the LMH6559 an ideal choice for the distribution of high frequency signals on printed circuit boards. Differential gain and phase specifications of 0.06% and 0.02° respectively at 3.58MHz make the LMH6559 well suited for the buffering of video signals.
The device is fabricated on Texas Instruments' high-speed VIP10 process using TI's proven high performance circuit architectures.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
