--- 产品详情 ---
片上电压参考为 2.5V 的精确对数和对数比放大器
Scale factor (V/decade) | 0.5 |
Input current range (Min) (nA) | 1 |
Input current range (Max) (mA) | 3.5 |
Conformity error (initial 5 decades) (Max) (%) | 0.2 |
Conformity error (initial 5 decades) (typ. over temp) (%/degree C) | 0.0001 |
Offset voltage (input amplifiers) (Max) (mV) | 1.5 |
Vs (+/-) (Min) (V) | 4.5 |
Vs (+/-) (Max) (V) | 18 |
Iq (Max) (mA) | 1.75 |
Dynamic range (Typ) (dB) | 150 |
Reference type | Internal |
Auxiliary op amps | 1 |
Full-scale output voltage (Min) (+/- V) | -3.8 |
Full-scale output voltage (Max) (+/- V) | 3.5 |
Operating temperature range (C) | -40 to 85 |
Specified voltage (+/- V) | 5 |
- EASY-TO-USE COMPLETE FUNCTION
- OUTPUT SCALING AMPLIFIER
- ON-CHIP 2.5V VOLTAGE REFERENCE
- HIGH ACCURACY: 0.2% FSO Over 5 Decades
- WIDE INPUT DYNAMIC RANGE:
???7.5 Decades, 100pA to 3.5mA - LOW QUIESCENT CURRENT: 1.75mA
- WIDE SUPPLY RANGE: ±4.5V to ±18V
- PACKAGES: SO-14 (narrow) and SO-16
- APPLICATIONS
- LOG, LOG RATIO:
???Communication, Analytical, Medical, Industrial, Test, General Instrumentation - PHOTODIODE SIGNAL COMPRESSION AMP
- ANALOG SIGNAL COMPRESSION IN FRONT OF ANALOG-TO-DIGITAL (A/D) CONVERTER
- ABSORBANCE MEASUREMENT
- OPTICAL DENSITY MEASUREMENT
- LOG, LOG RATIO:
All trademarks are the property of their respective owners.
The LOG112 and LOG2112 are versatile integrated circuits that compute the logarithm or log ratio of an input current relative to a reference current. VLOGOUT of the LOG112 and LOG2112 are trimmed to 0.5V per decade of input current, ensuring high precision over a wide dynamic range of input signals.
The LOG112 and LOG2112 features a 2.5V voltage reference that may be used to generate a precision current reference using an external resistor.
Low DC offset voltage and temperature drift allow accurate measurement of low-level signals over the specified temperature range of ?5°C to +75°C.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
