--- 产品详情 ---
具有关断功能的 175mA、+/-12V ADSL CPE 和 PLC 线路驱动器
Number of channels (#) | 2 |
Architecture | DSL Line Driver, PLC Line Driver |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 9 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 33 |
BW @ Acl (MHz) | 170 |
Acl, min spec gain (V/V) | 1 |
Vn at flatband (Typ) (nV/rtHz) | 2.1 |
Vn at 1 kHz (Typ) (nV/rtHz) | 2.1 |
Iq per channel (Typ) (mA) | 5.2 |
Vos (offset voltage @ 25 C) (Max) (mV) | 10 |
Rail-to-rail | No |
Features | Shutdown |
Rating | Catalog |
Operating temperature range (C) | -40 to 85, 0 to 70 |
CMRR (Typ) (dB) | 66 |
Input bias current (Max) (pA) | 10000000 |
Offset drift (Typ) (uV/C) | 30 |
GBW (Typ) (MHz) | 170 |
Output current (Typ) (mA) | 175 |
- Remote Terminal ADSL Line Driver
- Ideal for Both Full Rate ADSL and G.Lite
- Compatible With 1:1 Transformer Ratio
- Low 2.7 pA/Hz Noninverting Current Noise
- Reduces Noise Feedback Through Hybrid Into Downstream Channel
- Wide Supply Voltage Range ±5 V to ±15 V
- Ideal for ±12-V Operation
- Wide Output Swing
- 42 Vpp Differential Output Voltage, RL = 200 , ±12-V Supply
- High Output Current
- 175 mA (typ)
- High Speed
- 110 MHz (–3 dB, G=8, ±12 V)
- 1500 V/us Slew Rate (G = 8, ±12 V)
- Low Distortion, Single-Ended, G = 8
- –83 dBc (250 kHz, 2 Vpp, 100- load)
- Low Power Shutdown (THS6053)
- 300-uA Total Standby Current
- Thermal Shutdown and Short Circuit Protection
- Standard SOIC, SOIC PowerPAD, and TSSOP PowerPAD? Package
- Evaluation Module Available
PowerPAD is a trademark of Texas Instruments.
The THS6052/3 is a high-speed line driver ideal for driving signals from the remote terminal to the central office in asymmetrical digital subscriber line (ADSL) applications. It can operate from ±12-V supply voltages while drawing only 5.2 mA of supply current per channel. It offers low ?83 dBc total harmonic distortion driving a 100- load from a ±12-V supply. The THS6053 features a low-power shutdown mode, consuming only 300 uA quiescent current per channel. The THS6052/3 is packaged in a standard SOIC, SOIC PowerPAD?, and TSSOP PowerPAD? packages.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
