--- 产品详情 ---
Audio input type | Digital Input |
Architecture | Class-D, Smart Amp |
Speaker channels (Max) | Mono |
Power stage supply (Max) (V) | 23 |
Power stage supply (Min) (V) | 4.5 |
Load (Min) (ohms) | 3.2 |
Output power (W) | 25 |
SNR (dB) | 110 |
THD + N @ 1 kHz (%) | 0.006 |
Iq (Typ) (mA) | 15 |
Control interface | I2C, SPI, Shutdown Mode |
Closed/open loop | Closed |
Analog supply (Min) (V) | 1.65 |
Analog supply (Max) (V) | 1.95 |
Sampling rate (Max) (kHz) | 192 |
PSRR (dB) | 110 |
Operating temperature range (C) | -40 to 85 |
The TAS2781 is a mono, digital input Class-D audio amplifier optimized for efficiently driving high peak power into loudspeakers. The Class-D amplifier is capable of delivering 25 W of continuous power into a 4 Ω load with less than 1% THD+N at a supply voltage of 18 V. The broad voltage input range and the high output power makes this amplifier versatile enough to work with battery or line powered systems.
An on-chip DSP supports Texas Instruments Smart Amp speaker protection algorithm. The integrated speaker voltage and current sense provides for real-time monitoring of loudspeakers.
Y-Bridge power architecture improves amplifier efficiency by internally selecting the supplies for optimal headroom. Brownout prevention scheme with adjustable threshold allows reducing the gain in signal path when the supply drops.
The Hybrid-Pro algorithm allows user to optimize efficiency and improve battery life by controlling the external power supply.
Up to eight TAS2781 devices can share a common bus via I2S/TDM and I2C/SPI interfaces.
The TAS2781 is available in a 30 pin HR-QFN package for a compact PCB footprint.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
