--- 产品详情 ---
Output power (W) | 0.04 |
Analog supply (Min) (V) | 2 |
Analog supply (Max) (V) | 5.5 |
PSRR (dB) | 65 |
Rating | Automotive |
Operating temperature range (C) | -40 to 105 |
Headphone channels | Stereo |
Volume control | No |
Shutdown current (ISD) (uA) | 0.1 |
Architecture | Class-AB |
Iq per channel (Typ) (mA) | 1 |
The LM4911/LM4911Q is an stereo audio power amplifier capable of delivering 40mW per channel of continuous average power into a 16? load or 25mW per channel into a 32? load at 1% THD+N from a 3V power supply.
Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. Since the LM4911/LM4911Q does not require bootstrap capacitors or snubber networks, it is optimally suited for low-power portable systems. In addition, the LM4911/LM4911Q may be configured for either single-ended capacitively coupled outputs or for OCL outputs (patent pending).
The LM4911/LM4911Q features a low-power consumption shutdown mode and a power mute mode that allows for faster turn on time with less than 1mV voltage change at outputs on release. Additionally, the LM4911/LM4911Q features an internal thermal shutdown protection mechanism.
The LM4911/LM4911Q is unity gain stable and may be configured with external gain-setting resistors.
A Q-grade version is available for automotive applications. It is AEC-Q100 grade 2 qualified and packaged in a 10–pin MSOP package (LM4911QMM).
Key Specifications
PSRR at 217Hz and 1kHz | 65dB (typ) |
Output Power at 1kHz with VDD = 2.4V, 1% THD+N into a 16? load | |
Output Power at 1kHz with VDD = 3V, 1% THD+N into a 16? load | |
Shutdown Current | 2.0μA (max) |
Output Voltage change on release from Shutdown VDD = 2.4V, RL = 16? (C-Coupled) | |
Mute Current | 100μA (max) |
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
