--- 产品详情 ---
Audio input type | PWM |
Architecture | Class-D |
Speaker channels (Max) | 4 |
Power stage supply (Max) (V) | 34.1 |
Power stage supply (Min) (V) | 16 |
Load (Min) (ohms) | 4 |
Output power (W) | 125 |
SNR (dB) | 103 |
THD + N @ 1 kHz (%) | 0.03 |
Iq (Typ) (mA) | 21.5 |
Control interface | Hardware |
Closed/open loop | Closed |
Analog supply (Min) (V) | 10.8 |
Analog supply (Max) (V) | 13.2 |
PSRR (dB) | 80 |
Operating temperature range (C) | 0 to 70 |
- PurePath? HD Enabled Integrated Feedback Provides:
- Signal Bandwidth up to 80kHz for High Frequency Content From HD Sources
- Ultralow 0.03% THD at 1W into 4Ω
- Ultralow 0.01% THD at 1W into 8Ω
- Flat THD at all Frequencies for Natural Sound
- 80dB PSRR (BTL, No Input Signal)
- >100dB (A weighted) SNR
- Click and Pop Free Startup
- Pin compatible with TAS5631, TAS5616 and TAS5614
- Multiple Configurations Possible on the Same PCB With Stuffing Options:
- Mono Parallel Bridge Tied Load (PBTL)
- Stereo Bridge Tied Load (BTL)
- 2.1 Single Ended Stereo Pair and Bridge Tied Load Subwoofer
- Total Output Power at 10%THD+N
- 250W in Mono PBTL Configuration
- 125W per Channel in Stereo BTL Configuration
- Total Output Power in BTL configuration at 1%THD+N
- 130W Stereo into 3Ω
- 105W Stereo into 4Ω
- 70W Stereo into 6Ω
- 55W Stereo into 8Ω
- >90% Efficient Power Stage With 60-mΩ Output MOSFETs
- Self-Protection Design (Including Undervoltage, Overtemperature, Clipping,
and Short-Circuit Protection) With Error Reporting - EMI Compliant When Used With Recommended System Design
- Thermally Enhanced Package:
- PHD (64-Pin QFP)
- APPLICATIONS
- Home Theater Systems
- AV Receivers
- DVD/Blu-ray? Disc Receivers
- Mini Combo Systems
- Active Speakers and Subwoofers
All other trademarks are the property of their respective owners
The TAS5612A is a high performance digital input Class D amplifier with integrated closed loop feedback technology (known as PurePath? HD) with the ability to drive up to 125W Achievable output power levels are dependent on the thermal configuration of the target application. A high performance thermal interface material between the package exposed heatslug and the heat sink should be used to achieve high output power levels. Stereo into 4 to 8 Ω Speakers from a single 32.5V supply.
PurePath? HD technology enables traditional AB-Amplifier performance (<0.03% THD) levels while providing the power efficiency of traditional class D amplifiers.
Unlike traditional Class D amplifiers, the distortion curve only increases once the output levels move into clipping.
PurePath? HD technology enables lower idle losses making the device even more efficient.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
