--- 产品详情 ---
Audio input type | Analog Input |
Architecture | Class-D |
Speaker channels (Max) | Mono |
Power stage supply (Max) (V) | 5.5 |
Power stage supply (Min) (V) | 2.7 |
Load (Min) (ohms) | 4 |
Output power (W) | 2.6 |
SNR (dB) | 95 |
THD + N @ 1 kHz (%) | 0.03 |
Iq (Typ) (mA) | 3.1 |
Control interface | Hardware |
Closed/open loop | Open |
Analog supply (Min) (V) | 2.5 |
Analog supply (Max) (V) | 5.5 |
PSRR (dB) | 71 |
Operating temperature range (C) | -40 to 85 |
- Passes FCC Class B Radiated Emissions with 20 Inches of Cable
- E2S System Reduces EMI While Preserving Audio Quality and Efficiency
- Output Short Circuit Protection with Auto-Recovery
- No Output Filter Required
- Improved Audio Quality
- Minimum External Components
- Five Logic Selectable Gain Settings (0, 3, 6, 9, 12dB)
- Low Power Shutdown Mode
- Click and Pop Suppression
- Available in Space-Saving DSBGA Package
Key Specifications
- Efficiency at 3.6V, 400mW into 8?, 84% (Typ)
- Efficiency at 5V, 1W into 8?, 88% (Typ)
- Quiescent Power Supply Current at 5V, 3.1mA
- Power Output at VDD = 5V, RL = 4?
- THD+N ≤ 10%, 2.6W (Typ)
- THD+N ≤ 1%, 2.1W (Typ)
- Power Output at VDD = 5V, RL = 8?
- THD+N ≤ 10%, 1.6W (Typ)
- THD+N ≤ 1%, 1.3W (Typ)
- Shutdown Current, 0.01μA (Typ)
Boomer is a trademark of Texas Instruments. All trademarks are the property of their respective owners.
The LM48312 is a single supply, high efficiency, mono, 2.6W, filterless switching audio amplifier. The LM48312 features TI’s Enhanced Emissions Suppression (E2S) system, that features a unique patented ultra low EMI, spread spectrum, PWM architecture, that significantly reduces RF emissions while preserving audio quality and efficiency. The E2S system improves battery life, reduces external component count, board area consumption, and system cost, simplifying design.
The LM48312 is designed to meet the demands of portable multimedia devices. Operating from a single 5V supply, the device is capable of delivering 2.6W of continuous output power to a 4? load with less than 10% THD+N. Flexible power supply requirements allow operation from 2.4V to 5.5V. The LM48312 features both a spread spectrum modulation scheme, and an advanced, patented edge rate control (ERC) architecture that significantly reduces emissions, while maintaining high quality audio reproduction (THD+N = 0.03%) and high efficiency (η = 88%).
The LM48312 features high efficiency compared to conventional Class AB amplifiers, and other low EMI Class D amplifiers. When driving an 8? speaker from a 5V supply, the device operates with 88% efficiency at PO = 1W. The LM48312 features five gain settings, selected through a single logic input, further reducing solution size. A low power shutdown mode reduces supply current consumption to 0.01μA.
Advanced output short circuit protection with auto-recovery prevents the device from being damaged during fault conditions. Superior click and pop suppression eliminates audible transients on power-up/down and during shutdown.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
