--- 产品详情 ---
Audio input type | Analog Input |
Architecture | Class-D |
Speaker channels (Max) | Stereo |
Power stage supply (Max) (V) | 26 |
Power stage supply (Min) (V) | 8 |
Load (Min) (ohms) | 4 |
Output power (W) | 6 |
SNR (dB) | 102 |
THD + N @ 1 kHz (%) | 0.05 |
Iq (Typ) (mA) | 10 |
Control interface | Hardware |
Closed/open loop | Closed |
Analog supply (Min) (V) | 8 |
Analog supply (Max) (V) | 26 |
PSRR (dB) | 70 |
Operating temperature range (C) | -40 to 85 |
- 6-W/ch into an 8-Ω Loads at 10% THD+N From a
10-V Supply - 12-W into a 4-Ω Mono Load at 10% THD+N From
a 10-V Supply - 87% Efficient Class-D Operation Eliminates Need
for Heat Sinks - Wide Supply Voltage Range Allows Operation
from 8 V to 26 V - Filter-Free Operation
- SpeakerGuard Speaker Protection Includes
Adjustable Power Limiter Plus DC Protection - Flow-Through Pinout Facilitates Easy Board
Layout - Robust Pin-to-Pin Short-Circuit Protection and
Thermal Protection With Auto Recovery Option - Excellent THD+N and Pop-Free Performance
- Four Selectable, Fixed Gain Settings
- Differential Inputs
- APPLICATIONS
- Televisions
- Consumer Audio Equipment
- Monitors
All other trademarks are the property of their respective owners
The TPA3113D2 is a 6-W (per channel) efficient, Class-D audio power amplifier for driving bridged-tied stereo speakers. Advanced EMI Suppression Technology enables the use of inexpensive ferrite bead filters at the outputs while meeting EMC requirements. SpeakerGuard? speaker protection circuitry includes an adjustable power limiter and a DC detection circuit. The adjustable power limiter allows the user to set a virtual voltage rail lower than the chip supply to limit the amount of current through the speaker. The DC detect circuit measures the frequency and amplitude of the PWM signal and shuts off the output stage if the input capacitors are damaged or shorts exist on the inputs.
The TPA3113D2 can drive stereo speakers as low as 4 Ω. The high efficiency of the TPA3113D2, 87%, eliminates the need for an external heat sink when playing music.
The outputs are also fully protected against shorts to GND, VCC, and output-to-output. The short-circuit protection and thermal protection includes an auto-recovery feature.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
