--- 产品详情 ---
具有低 RDSon 的 100W 立体声、200W 单声道、0V 至 34V 电源电压、PWM 输入开环 D 类音频放大器
Audio input type | PWM |
Architecture | Class-D |
Speaker channels (Max) | 4 |
Power stage supply (Max) (V) | 13.2 |
Power stage supply (Min) (V) | 10.8 |
Load (Min) (ohms) | 2 |
Output power (W) | 100 |
SNR (dB) | 110 |
THD + N @ 1 kHz (%) | 0.09 |
Iq (Typ) (mA) | 5.6 |
Control interface | Hardware |
Closed/open loop | Open |
Analog supply (Min) (V) | 10.8 |
Analog supply (Max) (V) | 13.2 |
PSRR (dB) | 65 |
Operating temperature range (C) | 0 to 70 |
- Total Power Output (Bridge Tied Load)
- 2 × 100 W at 10% THD+N Into 4 Ω
- 2 × 80 W at 10% THD+N Into 6 Ω
- 2 × 65 W at 10% THD+N Into 8 Ω
- Total Power Output (Single Ended)
- 4 × 40 W at 10% THD+N Into 3 Ω
- 4 × 30 W at 10% THD+N Into 4 Ω
- Total Power Output (Parallel Mode)
- 1 × 200 W at 10% THD+N Into 2 Ω
- 1 × 160 W at 10% THD+N Into 3 Ω
- >110 dB SNR (A-Weighted With TAS5518 Modulator)
- <0.1% THD+N (1 W, 1 kHz)
- Supports PWM Frame Rates of 192?kHz to 432?kHz
- Resistor-Programmable Current Limit
- Integrated Self-Protection Circuitry, Including:
- Under Voltage Protection
- Overtemperature Warning and Error
- Overload Protection
- Short-Circuit Protection
- PWM Activity Detector
- Standalone Protection Recovery
- Power-On Reset (POR) to Eliminate System Power-Supply Sequencing
- High-Efficiency Power Stage (>90%) With 110-mΩ Output MOSFETs
- Thermally Enhanced Package 44-Pin HTSSOP (DDV)
- Error Reporting, 3.3-V and 5-V Compliant
- EMI Compliant When Used With Recommended System Design
The TAS5342LA is a high-performance, integrated stereo digital amplifier power stage designed to drive a 4-Ω bridge-tied load (BTL) at up to 100 W per channel with low-harmonic distortion, low-integrated noise, and low-idle current.
The TAS5342LA has a complete protection system integrated on-chip, safeguarding the device against a wide range of fault conditions that could damage the system. These protection features are short-circuit protection, over-current protection, under voltage protection, over temperature protection, and a loss of PWM signal (PWM activity detector).
A power-on-reset (POR) circuit is used to eliminate power-supply sequencing that is required for most power-stage designs.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
