--- 产品详情 ---
带硬件控制功能的 20W 立体声、0V 至 21V 电源电压、数字输入、开环 D 类音频放大器
Audio input type | Digital Input |
Architecture | Class-D |
Speaker channels (Max) | Stereo |
Power stage supply (Max) (V) | 21 |
Power stage supply (Min) (V) | 10 |
Load (Min) (ohms) | 6 |
Output power (W) | 20 |
SNR (dB) | 100 |
THD + N @ 1 kHz (%) | 0.05 |
Iq (Typ) (mA) | 30 |
Control interface | Hardware |
Closed/open loop | Open |
Analog supply (Min) (V) | 3 |
Analog supply (Max) (V) | 3.6 |
Sampling rate (Max) (kHz) | 192 |
PSRR (dB) | 60 |
Operating temperature range (C) | 0 to 85 |
- Audio Input/Output
- 20-W Into an 8- Load From an 18-V Supply
- Wide PVDD Range (0 V to 21 V)
- Efficient Class-D Operation Eliminates Need for Heat Sinks
- Two Serial Audio Inputs (3 Audio channels)
- Supports 32-kHz to 192-kHz Sample Rates (LJ/RJ/I2S)
- Line-Level Subwoofer PWM Outputs
- Audio/PWM Processing
- BD (Filter-free) Modulation Supporting Bridge-Tied Loads ONLY
- 4-Step Volume Control (0 dB, 6 dB, 12 dB, 18 dB)
– All Channels Share Same Control - Soft Mute (50% Duty Cycle)
- DC Blocking Filters
- Fixed Maximum Modulation Limit At 97.7%
- ≥100-dB SNR – Measured at Maximum Output With THD+N = 1%, 1 kHz,
A-Weighted Noise, Gain = 0 dB - THD < 0.1% at 1/2 Rated Power
- General Features
- 5-V Tolerant Inputs (See pin list for details on which inputs are 5-V tolerant)
- Shutdown Mode for Low Power Consumption
- Thermal and Short-Circuit Protection
- Autodetect: Automatically Detect Sample-Rate Changes –
No Need for External Microprocessor Intervention
The TAS5701 is a 20-W efficient, digital audio power amplifier for driving stereo bridge-tied speakers. Two serial data inputs support up to 3 discrete audio channels. The SDIN1 input is routed to the internal left and right outputs. The SDIN2 input is dedicated to the SUB_PWM± outputs.
The TAS5701 is a clock slave-only device receiving clocks from external sources. The TAS5701 operates at a 384-kHz switching rate for 32-, 48-, 96-, and 192-kHz data and 352.8-kHz switching rate 44.1-,88.2-, and 176.4-kHz data. The 8× oversampling combined with the fourth-order noise shaper provides a flat noise floor and excellent dynamic range from 20 Hz to 20 kHz.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
