--- 产品详情 ---
Audio input type | Digital Input |
Architecture | Class-D |
Speaker channels (Max) | 4 |
Power stage supply (Max) (V) | 26 |
Power stage supply (Min) (V) | 10 |
Load (Min) (ohms) | 4 |
Output power (W) | 20 |
SNR (dB) | 100 |
THD + N @ 1 kHz (%) | 0.05 |
Iq (Typ) (mA) | 33 |
Control interface | Hardware |
Closed/open loop | Closed |
Analog supply (Min) (V) | 3 |
Analog supply (Max) (V) | 3.6 |
Sampling rate (Max) (kHz) | 192 |
PSRR (dB) | 60 |
Operating temperature range (C) | 0 to 85 |
- Audio Input/Output
- 20-W into an 8-
Load From an 18-V Supply
- Two Serial Audio Inputs (Four Audio Channels)
- Supports Multiple Output Configurations:
- 2-Ch Bridged Outputs (20 W × 2)
- 4-Ch Single-Ended Outputs (10 W × 4)
- 2-Ch Single-Ended + 1-Ch Bridged (2.1) (10 W × 2 + 20 W)
- 20-W into an 8-
- Closed Loop Power Stage Architecture
- Improved PSRR Reduces Power Supply Performance Requirements
- Higher Damping Factor Provides for Tighter, More Accurate
Sound With Improved Bass Response - Lower EMC Emissions
- Output Power is Independent of Supply Voltage Variation
- Wide PVCC Range From (10?V to 26?V)
- Supports 32-kHz–192-kHz (DVD-Audio) Sample Rates (LJ/RJ/I2S)
- Line-Level Subwoofer PWM Outputs
- Audio/PWM Processing (Hardware Controlled)
- 4-Step Gain Control (-3dB, 3dB, 9dB, 12dB)
- Soft Mute Control (50% Output Duty Cycle)
- Factory-Trimmed Internal Oscillator Enables Automatic Detection of
Incoming Sample Rates - Thermal and Short-Circuit Protection
System Two, Audio Precision are trademarks of Audio Precision, Inc.
The TAS5704 is a 20-W, efficient, digital audio power amplifier for driving stereo bridge-tied speakers. Two serial data inputs allow processing of up to four discrete audio channels and seamless integration to most digital audio processors accepting a wide range of input data and clock rates. A hardware configurable data path allows these channels to be routed to the internal speaker drivers or output via the subwoofer PWM outputs.
The TAS5704 is a slave-only device receiving all clocks from external sources. The TAS5704 operates at a 384-kHz switching rate for 32-, 48-, 96-, and 192-kHz data, and at a 352.8 kHz switching rate for 44.1-, 88.2-, and 176.4-kHz data. The 8× oversampling combined with the fourth-order noise shaper provides a flat noise floor and excellent dynamic range from 20?Hz to 20??kHz.
The closed-loop architecture of the TAS5704 provides several benefits. The high power supply rejection enables superior audio performance from a noisy, low cost supply. The high damping factor allows tighter control over speaker movement resulting in an improved bass response. Finally, switching edge rate control lowers EMC emissions without sacrificing audio performance.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
