--- 产品详情 ---
单通道、110MHz、高保真、高电流耳机缓冲器
Number of channels (#) | 1 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 4.5 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 36 |
GBW (Typ) (MHz) | 180 |
Slew rate (Typ) (V/us) | 2000 |
Rail-to-rail | No |
Vos (offset voltage @ 25 C) (Max) (mV) | 60 |
Iq per channel (Typ) (mA) | 14 |
Vn at 1 kHz (Typ) (nV/rtHz) | 3 |
THD + N @ 1 kHz (Typ) (%) | 0.00003 |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
Output current (Typ) (mA) | 250 |
Architecture | Voltage FB |
CMRR (Typ) (dB) | 0 |
Input bias current (Max) (pA) | 5000000 |
- Pin-Selectable Bandwidth and Quiescent Current
- Pure Fidelity, Pure Performance
- Short Circuit Protection
- Thermal Shutdown
- TO–263 Surface-Mount Package
Key Specifications
- Low THD+N (VOUT = 3VRMS, f = 1kHz, ): 0.00003% (typ)
- Slew Rate: 2000V/μs (typ)
- High Output Current: 250mA (typ)
- Bandwidth
- ?BW Pin Floating: 110MHz (typ)
- ?BW Connected to VEE: 180MHz (typ)
- Supply Voltage Range: ±2.25V ≤ VS ≤ ±18V
All trademarks are the property of their respective owners.
The LME49600 is a high performance, low distortion high fidelity 250mA audio buffer. The LME49600 is designed for a wide range of applications. It can be used inside the feedback loop of op amps.
The LME49600 offers a pin-selectable bandwidth: a low current, 110MHz bandwidth mode that consumes 7.3mA and a wide 180MHz bandwidth mode that consumes 13.2mA. In both modes the LME49600 has a nominal 2000V/μs slew rate. Bandwidth is easily adjusted by either leaving the BW pin unconnected or connecting a resistor between the BW pin and the VEE pin.
The LME49600 is fully protected through internal current limit and thermal shutdown.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
