--- 产品详情 ---
具有直流音量控制和立体声耳机驱动器的 2W、立体声、AB 类音频放大器
Audio input type | Analog Input |
Architecture | Class-AB |
Speaker channels (Max) | Stereo |
Power stage supply (Max) (V) | 5.5 |
Power stage supply (Min) (V) | 4 |
Load (Min) (ohms) | 4 |
Output power (W) | 2 |
THD + N @ 1 kHz (%) | 0.8 |
Iq (Typ) (mA) | 5 |
Control interface | Hardware |
Closed/open loop | Open |
Analog supply (Min) (V) | 4 |
Analog supply (Max) (V) | 5.5 |
PSRR (dB) | 70 |
Operating temperature range (C) | -40 to 85 |
- 2 W Into 4- Speakers With External Heatsink
- DC Volume Control With 2-dB
Steps from -40 dB to 20 dB- Fade Mode
- -85-dB Mute Mode
- Differential Inputs
- 1-μA Shutdown Current (Typical)
- Headphone Mode
- APPLICATIONS
- LCD Monitors
The TPA6021A4 is a stereo audio power amplifier that drives 2 W/channel of continuous RMS power into a 4- load when utilizing a heat sink. Advanced dc volume control minimizes external components and allows BTL (speaker) volume control and SE (headphone) volume control.
The 20-pin DIP package allows for the use of a heatsink which provides higher output power.
To ensure a smooth transition between active and shutdown modes, a fade mode ramps the volume up and down.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
