--- 产品详情 ---
Audio input type | Analog Input |
Architecture | Class-D |
Speaker channels (Max) | Stereo |
Power stage supply (Max) (V) | 5.5 |
Power stage supply (Min) (V) | 2.8 |
Load (Min) (ohms) | 4 |
Output power (W) | 1.2 |
SNR (dB) | 83 |
THD + N @ 1 kHz (%) | 0.65 |
Iq (Typ) (mA) | 15 |
Control interface | Hardware |
Closed/open loop | Closed |
Analog supply (Min) (V) | 2.8 |
Analog supply (Max) (V) | 5.5 |
PSRR (dB) | 65 |
Operating temperature range (C) | -40 to 85 |
- No Output Filter Required for Inductive Transducers
- Selectable Gain of 6dB or 12dB
- Very Fast Turn On Time: 6ms (typ)
- Minimum External Components
- "Click and Pop" Suppression Circuitry
- Micro-Power Shutdown Mode
- Short Circuit Protection
- Available in Space-Saving NHK0014A Package
Key Specifications
- Efficiency at 3V, 100mW into 8? Transducer: 79% (typ)
- Efficiency at 3V, 450mW into 8? Transducer: 84% (typ)
- Efficiency at 5V, 1W into 8? Transducer: 85% (typ)
- Total Quiescent Power Supply Current: 7.0mA (typ)
- Total Shutdown Power Supply Current: 0.02μA (typ)
- Single supply range: 2.8V to 5.5V
All trademarks are the property of their respective owners.
The LM4666 is a fully integrated single-supply high efficiency switching audio amplifier. It features an innovative modulator that eliminates the LC output filter used with typical switching amplifiers. Eliminating the output filter reduces parts count, simplifies circuit design, and reduces board area. The LM4666 processes analog inputs with a delta-sigma modulation technique that lowers output noise and THD when compared to conventional pulse width modulators.
The LM4666 is designed to meet the demands of mobile phones and other portable communication devices. Operating on a single 3V supply, it is capable of driving 8? transducer loads at a continuous average output of 450mW with less than 1%THD+N. Its flexible power supply requirements allow operation from 2.8V to 5.5V.
The LM4666 has high efficiency with an 8? transducer load compared to a typical Class AB amplifier. With a 3V supply, the IC's efficiency for a 100mW power level is 79%, reaching 84% at 450mW output power.
The LM4666 features a low-power consumption shutdown mode. Shutdown may be enabled by driving the Shutdown pin to a logic low (GND).
The LM4666 has fixed selectable gain of either 6dB or 12dB. The LM4666 has short circuit protection against a short from the outputs to VDD or GND.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
