--- 产品详情 ---
具有集成静音功能的 11W 立体声、9V 至 40V 电源电压、模拟输入 AB 类音频放大器
Audio input type | Analog Input |
Architecture | Class-AB |
Speaker channels (Max) | Stereo |
Power stage supply (Max) (V) | 40 |
Power stage supply (Min) (V) | 9 |
Load (Min) (ohms) | 4 |
Output power (W) | 11 |
THD + N @ 1 kHz (%) | 0.08 |
Iq (Typ) (mA) | 5 |
Control interface | Hardware |
Closed/open loop | Closed |
Analog supply (Min) (V) | 9 |
Analog supply (Max) (V) | 40 |
PSRR (dB) | 50 |
Operating temperature range (C) | -20 to 80 |
- Drives 4? and 8? Loads
- Integrated Mute Function
- Internal Gain Resistors
- Minimal External Components Needed
- Single Supply Operation
- Internal Current Limiting and Thermal Protection
- Compact 9-lead TO-220 Package
- Wide Supply Range 9V - 40V
Key Specifications
- Output Power at 10% THD with 1kHz into 4? at VCC = 24V 11 W (typ)
- Output Power at 10% THD with 1kHz into 8? at VCC = 24V 7 W (typ)
- Closed Loop Gain 34 dB (typ)
- PO at 10% THD+N @ 1kHz into 4? Single-Ended DDPAK Package at VCC=12V 2.5 W (typ)
- PO at 10% THD+N @ 1kHz into 8? Bridged DDPAK Package at VCC=12V 5 W (typ)
All trademarks are the property of their respective owners.
The LM4755 is a stereo audio amplifier capable of delivering 11W per channel of continuous average output power to a 4? load or 7W per channel into 8? using a single 24V supply at 10% THD+N. The internal mute circuit and pre-set gain resistors provide for a very economical design solution.
Output power specifications at both 20V and 24V supplies and low external component count offer high value to consumer electronic manufacturers for stereo TV and compact stereo applications. The LM4755 is specifically designed for single supply operation.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
