--- 产品详情 ---
Output power (W) | 0.15 |
Analog supply (Min) (V) | 2.7 |
Analog supply (Max) (V) | 5.5 |
PSRR (dB) | 50 |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
Headphone channels | Stereo |
Volume control | No |
Shutdown current (ISD) (uA) | 0.7 |
Architecture | Class-AB |
Iq per channel (Typ) (mA) | 1.8 |
- VSSOP Surface Mount Packaging
- Unity-gain Stable
- External Gain Configuration Capability
- Thermal Shutdown Protection Circuitry
- No Bootstrap Capacitors, or Snubber Circuits are Necessary
Key Specifications
- THD+N at 1kHz at 125mW Continuous Average Output Power into 8? 0.1% (max)
- THD+N at 1kHz at 75mW Continuous
0.02% (typ) - Output Power at 10% THD+N at 1kHz into 8? 300 mW (typ)
- Shutdown Current 0.7μA (typ)
- Supply Voltage Range 2.7V to 5.5 V
All trademarks are the property of their respective owners. Boomer is a trademark of Texas Instruments.
The LM4881 is a dual audio power amplifier capable of delivering 200mW of continuous average power into an 8? load with 0.1% THD+N from a 5V power supply.
Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components using surface mount packaging. Since the LM4881 does not require bootstrap capacitors or snubber networks, it is optimally suited for low-power portable systems.
The LM4881 features an externally controlled, low power consumption shutdown mode which is virtually clickless and popless, as well as an internal thermal shutdown protection mechanism.
The unity-gain stable LM4881 can be configured by external gain-setting resistors.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
