--- 产品详情 ---
Dual, 30-V, 3-MHz, low noise (8-nV/√Hz) operational amplifier
Number of channels (#) | 2 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 10 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 30 |
GBW (Typ) (MHz) | 3 |
Slew rate (Typ) (V/us) | 1.7 |
Rail-to-rail | No |
Vos (offset voltage @ 25 C) (Max) (mV) | 6 |
Iq per channel (Typ) (mA) | 1.25 |
Vn at 1 kHz (Typ) (nV/rtHz) | 8 |
Features | Standard Amps |
THD + N @ 1 kHz (Typ) (%) | 0.0005 |
Rating | Catalog |
Operating temperature range (C) | -40 to 85, 0 to 70 |
Output current (Typ) (mA) | 10 |
Architecture | Bipolar |
CMRR (Typ) (dB) | 90 |
Input bias current (Max) (pA) | 500000 |
- Continuous Short-Circuit Protection
- Wide Common-Mode and Differential Voltage Ranges
- No Frequency Compensation Required
- Low Power Consumption
- No Latch-Up
- Unity-Gain Bandwidth: 3 MHz Typ
- Gain and Phase Match Between Amplifiers
- Low Noise: 8 nV/√Hz Typ at 1 kHz
- APPLICATIONS
- DVD Recorders and Players
- Pro Audio Mixers
All other trademarks are the property of their respective owners
The RC4558 device is a dual general-purpose operational amplifier, with each half electrically similar to the μA741, except that offset null capability is not provided.
The high common-mode input voltage range and the absence of latch-up make this amplifier ideal for voltage-follower applications. The device is short-circuit protected, and the internal frequency compensation ensures stability without external components.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
