--- 产品详情 ---
Audio input type | Analog Input |
Architecture | Class-AB |
Speaker channels (Max) | Mono |
Power stage supply (Max) (V) | 26 |
Power stage supply (Min) (V) | 12 |
Load (Min) (ohms) | 4 |
Output power (W) | 5 |
THD + N @ 1 kHz (%) | 0.25 |
Iq (Typ) (mA) | 8.5 |
Control interface | Hardware |
Closed/open loop | Open |
Analog supply (Min) (V) | 12 |
Analog supply (Max) (V) | 26 |
PSRR (dB) | 31 |
Operating temperature range (C) | 0 to 70 |
- Wide Supply Voltage Range: 12V to 26V
- Low Quiescent Power Drain
- Voltage Gain Fixed at 50
- High Peak Current Capability: 1.3A
- Input Referenced to GND
- High Input Impedance: 150k?
- Low Distortion: 0.25% (PO=4W, RL=8?)
- Quiescent Output Voltage is at One Half of the Supply Voltage
- 14-Pin PDIP Package
All trademarks are the property of their respective owners.
The LM384 is a power audio amplifier for consumer applications. In order to hold system cost to a minimum, gain is internally fixed at 34 dB. A unique input stage allows ground referenced input signals. The output automatically self-centers to one-half the supply voltage.
The output is short-circuit proof with internal thermal limiting. The package outline is standard dual-in-line. A copper lead frame is used with the center three pins on either side comprising a heat sink. This makes the device easy to use in standard p-c layout.
Uses include simple phonograph amplifiers, intercoms, line drivers, teaching machine outputs, alarms, ultrasonic drivers, TV sound systems, AM-FM radio and sound projector systems. See SNAA086 for circuit details.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
