--- 产品详情 ---
Number of ADC channels | 1 |
Analog inputs | 1 |
Digital audio interface | DSP, PCM |
Control interface | H/W |
Sampling rate (Max) (kHz) | 108 |
ADC SNR (Typ) (dB) | 112 |
Rating | Catalog |
- High-Performance Delta-Sigma Analog-to-Digital Converter
- Differential Voltage Inputs
- Dynamic Performance:
- Dynamic Range (A-Weighted): Up to 112dB
- THD+N: As low as -105dB
- Three Sampling Modes:
- Supports Output Sampling Rates Up to 108kHz
- Choose from Low Power, High-Performance, or Double Speed Modes
- Audio Serial Port Interface:
- Master or Slave Mode Operation
- 24-Bit Linear PCM Output Data
- Left-Justified/DSP-Compatible Data Format
- Digital High-Pass Filter for DC Removal:
- Includes a High-Pass Filter Disable Pin
- Power Supplies:
- Requires a +5V Analog Power Supply
- Supports a +1.8V to +3.3V Digital Power Supply Range
- Low Power Dissipation
- 49mW Typical (Low Power Mode with VDD = +3.3V)
- 39mW Typical (Low Power Mode with VDD = +1.8V)
- Power Down Mode
- Less than 50μW total power dissipation
- Available in a small TSSOP-16 Package
- APPLICATIONS
- Digital Wireless Microphones
- Battery-Powered Audio Recording and Processing Equipment
I2S is a registered trademark of Royal Philips Electronics B.V., The Netherlands.
All other trademarks are the property of their respective owners.
The PCM4201 is designed for digital audio applications that require a combination of high dynamic range, low distortion, and low power consumption. The primary applications for the PCM4201 include digital wireless microphones and battery-operated audio recording or processing equipment. The PCM4201 outputs 24-bit linear PCM audio data at sampling rates up to 108kHz. Three sampling modes allow the user to trade off power for performance, dependent upon the intended system requirements. An on-chip voltage reference reduces the number of external components needed for operation.
The PCM4201 includes dedicated control pins for configuration of all programmable functions. The device requires a +5.0V analog power supply, in addition to a digital supply operating from +1.8V to +3.3V. The PCM4201 is available in a small TSSOP-16 package.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
