--- 产品详情 ---
Number of ADC channels | 2 |
Number of DAC channels (#) | 2 |
Digital audio interface | R, L |
Analog inputs | 2 |
Sampling rate (Max) (kHz) | 48 |
Rating | Catalog |
ADC SNR (Typ) (dB) | 88 |
DAC SNR (Typ) (dB) | 92 |
- 16-Bit Delta-Sigma ADC and DAC
- Stereo ADC:
- Single-Ended Voltage Input
- Anti-Aliasing Filter Included
- High Performance
- THD+N: -84 dB
- SNR: 88 dB
- Dynamic Range: 88 dB
- 1/64× Decimation Digital Filter
- Passband Ripple: ±0.05 dB
- Stopband Attenuation: -65 dB
- Digital HPF Included
- Stereo DAC:
- Single-Ended Voltage Output
- Analog LPF and FIR Filter Included
- High Performance
- THD+N: -88 dB
- SNR: 92 dB
- Dynamic Range: 92 dB
- 8× Oversampling Digital Filter
- Passband Ripple: ±0.1 dB
- Stopband Attenuation: -43 dB
- Audio Data Format:
- ADC: 16-bit, Left-Justified
- DAC: 16-bit, Right-Justified
- Special Built-In Functions:
- Digital De-Emphasis: 32, 44.1, 48 kHz
- ADC/DAC Independent Power Down With Pop-Noise Free Muting
- Sampling Rate: 8 kHz to 48 kHz
- System Clock: 256fS, 384fS, 512fS
- Low Voltage Power Supply:
- 2.4 V TYP, 2.1 V MIN to 3.6 V MAX
- Low Power Dissipation:
- 32 mW at VCC = 2.4 V
- Package: 16-Pin TSSOP
- APPLICATIONS
- Digital Video Camera
- Portable MD Player
- Other Portable System
The PCM3008 is a low cost single chip 16-bit stereo audio codec with single-ended analog voltage input and output.
Both ADCs and DACs employ delta-sigma modulation with 64-times oversampling. ADCs include a digital decimation filter and digital high pass filter. DACs include an 8-times oversampling digital interpolation filter, digital de-emphasis filter and pop-noise free muting which works during the power down ON/OFF sequence. The PCM3008 accepts left-justified format for ADC, and right-justified format for DAC. Independent power-down modes for ADC and DAC are provided.
The PCM3008 is suitable for a wide variety of cost-sensitive consumer applications where good performance is required. It is fabricated using a highly advanced CMOS process and is available in a small 16-pin TSSOP package.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
