--- 产品详情 ---
具有单端输入的 93dB SNR 立体声 ADC
Number of ADC channels | 2 |
Analog inputs | 2 |
Digital audio interface | I2S, L |
Control interface | H/W |
Sampling rate (Max) (kHz) | 48 |
ADC SNR (Typ) (dB) | 93 |
Rating | Catalog |
- Dual 16-Bit Monolithic ADC
- Single-Ended Voltage Input
- Antialiasing Filter Included
- 64× Oversampling Decimation Filter:
Pass-Band Ripple: ±0.05 dB
Stop-Band Attenuation: -65 dB - Analog Performance:
THD+N: -88 dB (typical)
SNR: 93 dB (typical)
Dynamic Range: 93 dB (typical)
Internal High-Pass Filter - PCM Audio Interface: Left-Justified, I2S
- Sampling Rate: 4 kHz to 48 kHz
- System Clock: 256 fS, 384 fS, or 512 fS
- Single 5-V Power Supply
- Small SO-14 Package
- APPLICATIONS
- DVD Recorders
- DVD Receivers
- AV Amplifier Receivers
- Electric Musical Instruments
System Two, Audio Precision are trademarks of Audio Precision, Inc.
All other trademarks are the property of their respective owners.
The PCM1801 is a low-cost, single-chip stereo analog-to-digitalconverter (ADC) with single-ended analog voltage inputs. The PCM1801 uses a delta-sigma modulator with 64 times oversampling, a digital decimation filter, and a serial interface that supports slave mode operation and two data formats. The PCM1801 is suitable for a wide variety of cost-sensitive consumer applications where good performance is required.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
