--- 产品详情 ---
Resolution (Bits) | 12 |
Number of input channels | 8 |
Sample rate (Max) (kSPS) | 100 |
Interface type | SPI |
Architecture | SAR |
Input type | Differential, Single-Ended |
Multi-channel configuration | Multiplexed |
Rating | Catalog |
Reference mode | Ext |
Input range (Max) (V) | 5.5 |
Input range (Min) (V) | 0 |
Features | Oscillator, PGA |
Operating temperature range (C) | -40 to 85 |
Power consumption (Typ) (mW) | 1.32 |
Analog voltage AVDD (Min) (V) | 2.2 |
Analog voltage AVDD (Max) (V) | 5.5 |
INL (Max) (+/-LSB) | 1.5 |
Digital supply (Min) (V) | 2.2 |
Digital supply (Max) (V) | 5.5 |
- Low-Power, Flexible Supply Range:
- 2.2V to 5.5V Analog Supply
- 1.32mW (100kHz, +VA = 2.2V, +VD = 2.2V)
- 4.5mW (100kHz, +VA = 5V, +VD = 5V)
- Up to 100kSPS Throughput Rate
- Excellent DC Performance:
- ±0.5 LSB typ, ±1.5 LSB max INL
- ±0.5 LSB typ, ±1.0 LSB max DNL
- ±6 LSB Offset Error at +VA =5V
- ±0.1%FS Gain Error at +VA = 5V
- Flexible Analog Inputs:
- True Differential Input
- Differential/Unipolar Input Range (0 to VREF)
- TAG Bit Output
- Programmable Averaging Function
- Onboard, Eight Single-Ended/Four Differential Channel Mux:
- High Input Impedance
- High-Performance PGA (Gain = 1/2/4/8)
- PGA Breakout
- Auto/Manual Channel Select with Gain
- Auto/Manual Trigger
- Mixed Type Partial Scan
- Built-in Hardware Features:
- On-chip Conversion Clock (CCLK)
- Hardware/Software Reset
- Programmable Status/Polarity for BUSY/INT
- Flexible I/O:
- SPI-/DSP?-Compatible Serial Interface
- Separate I/O Supply (2.2V to 5.5V)
- Onboard 8×1 FIFO Buffer
- SCLK up to 25MHz (VD = 5V)
- Multi-Chip Ready and Fully Enabled:
- Global CONVST (Independent of CS)
- Power-Down Mode
- 24-Pin 4×4 QFN Package
- APPLICATIONS
- Portable Communications
- Transducer Interfaces
- Portable Medical Instruments
- Data Acquisition Systems
- GPS Chipsets
DSP is a trademark of Texas Instruments.
SPI is a trademark of Motorola Inc.
All other trademarks are the property of their respective owners
The ADS8201 is a low-power, complete on-chip data acquisition system optimized for portable applications that require direct connections, wide dynamic range, and automatic operation with very low power consumption. The device includes a 12-bit, capacitor-based, successive approximation register (SAR) analog-to-digital converter (ADC); a high-performance, continuous-time programmable gain amplifier (PGA); and a fully automatic scan, 8-to-1 multiplexer (mux) with breakout to allow for system design flexibility.
Many other features are included to further optimize system operation. Conversion results may be saved in an onboard first-in/first-out (FIFO) buffer and read out at a later time. Each channel has a gain setting that can be loaded automatically when it is selected. To simplify the serial port design, the ADS8201 offers a high-speed, wide-voltage serial interface. The ADS8201 is ideal for sensor applications (for example, bridge sensors, pressure sensors, accelerometers, gyrosensors, temperature sensors, etc.) as used in gaming and navigation.
The ADS8201 is available in a 24-lead, 4×4 QFN package, and is specified over the –40°C to +85°C industrial temperature range.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
