--- 产品详情 ---
八通道、12 位、65MSPS 模数转换器 (ADC)
Sample rate (Max) (MSPS) | 65 |
Resolution (Bits) | 12 |
Number of input channels | 8 |
Interface type | Serial LVDS |
Analog input BW (MHz) | 520 |
Features | Low Power |
Rating | Catalog |
Input range (Vp-p) | 2 |
Power consumption (Typ) (mW) | 616 |
Architecture | Pipeline |
SNR (dB) | 70 |
ENOB (Bits) | 11.3 |
SFDR (dB) | 85 |
Operating temperature range (C) | -40 to 85 |
Input buffer | No |
- Speed and Resolution Grades:
- ADS5281: 12-bit, 50MSPS
- ADS5282: 12-bit, 65MSPS
- Power Dissipation:
- 48mW/Channel at 30MSPS
- 55mW/Channel at 40MSPS
- 64mW/Channel at 50MSPS
- 77mW/Channel at 65MSPS
- 70dBFS SNR at 10MHz IF
- Analog Input Full-Scale Range: 2VPP
- Low-Frequency Noise Suppression Mode
- 6dB Overload Recovery In One Clock
- External and Internal (Trimmed) Reference
- 3.3V Analog Supply, 1.8V Digital Supply
- Single-Ended or Differential Clock:
- Clock Duty Cycle Correction Circuit (DCC)
- Programmable Digital Gain: 0dB to 12dB
- Serialized DDR LVDS Output
- Programmable LVDS Current Drive, Internal Termination
- Test Patterns for Enabling Output Capture
- Straight Offset Binary or Two’s Complement Output
- Package Options:
- 9mm × 9mm QFN-64
- HTQFP-80 PowerPAD Compatible with ADS527x Family
The ADS528x is a family of high-performance, low-power, octal channel analog-to-digital converters (ADCs). Available in either a 9mm × 9mm QFN package or an HTQFP-80 package, with serialized low-voltage differential signaling (LVDS) outputs and a wide variety of programmable features, the ADS528x is highly customizable for a diversity of applications and offers an unprecedented level of system integration. An application note, XAPP774 (available at www.xilinx.com), describes how to interface the serial LVDS outputs of TI&3146;s ADCs to Xilinx field-programmable gate arrays (FPGAs). The ADS528x family is specified over the industrial temperature range of –40°C to +85°C.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
