--- 产品详情 ---
Resolution (Bits) | 20 |
Number of input channels | 1 |
Sample rate (Max) (kSPS) | 25 |
Interface type | SPI |
Architecture | Delta-Sigma |
Input type | Differential, Single-Ended |
Rating | Catalog |
Reference mode | Ext |
Input range (Max) (V) | 4.196 |
Input range (Min) (V) | 0 |
Features | PGA |
Operating temperature range (C) | -40 to 85 |
Power consumption (Typ) (mW) | 75 |
Analog voltage AVDD (Min) (V) | 4.75 |
Analog voltage AVDD (Max) (V) | 5.25 |
INL (Max) (+/-LSB) | 21 |
Digital supply (Min) (V) | 4.75 |
Digital supply (Max) (V) | 5.25 |
- DATA RATE: 25kHz
- DIFFERENTIAL INPUTS
- LOW NOISE: 2.8ppm at PGA = 1
- INL: 0.002%
- 20 BITS NO MISSING CODES
- PROGRAMMABLE FULL SCALE
- EXTERNAL REFERENCE
- I/O CONTROLLED PGA: 1, 2, 4, 8
The ADS1250 is a precision, wide dynamic range, delta-sigma, analog-to-digital converter with 20-bit resolution operating from a single +5V supply. The delta-sigma architecture is used for wide dynamic range and to guarantee 20 bits of no missing code performance. An effective resolution of 18 bits (2.8ppm of rms noise) is achieved for conversion rates up to 25kHz. The dynamic range of the converter is further increased by providing a low-noise Programmable Gain Amplifier (PGA) with gain stages of 1, 2, 4, or 8 for low level input signals.
The ADS1250 is designed for high-resolution measurement applications in cardiac diagnostics, smart transmitters, industrial process control, weigh scales, chromatography and portable instrumentation. The converter includes a flexible synchronous serial interface and offers a three-wire control mode for low-cost isolation.
The ADS1250 is a single-channel converter and is offered in an SOL-16 package.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
