--- 产品详情 ---
Resolution (Bits) | 14 |
Number of DAC channels (#) | 2 |
Interface type | Parallel |
Output type | Unbuffered Current |
Settling time (μs) | 0.5 |
Features | Reset to Mid-Scale |
Reference type | Ext |
Architecture | Multiplying DAC |
Rating | Catalog |
Output range (Max) (mA/V) | 2 |
Output range (Min) (mA/V) | 0 |
Operating temperature range (C) | -40 to 125 |
- ±0.5LSB DNL
- ±0.5LSB INL
- Low Noise: 12nV/
Hz
- Low Power: IDD = 1μA per channel at 2.7V
- 2mA Full-Scale Current, with VREF = 10V
- Settling Time: 0.5μs
- 14-Bit Monotonic
- 4-Quadrant Multiplying Reference Inputs
- Reference Bandwidth: 10MHz
- Reference Input: ±18V
- Reference Dynamics: -105 THD
- Midscale or Zero Scale Reset
- Analog Power Supply: +2.7V to +5.5V
- TSSOP-38 Package
- Industry-Standard Pin Configuration
- Pin Compatible with the 16-Bit DAC8822
- Temperature Range: -40°C to +125°C
- APPLICATIONS
- Automatic Test Equipment
- Instrumentation
- Digitally Controlled Calibration
- Industrial Control PLCs
All trademarks are the property of their respective owners
The DAC8805 dual, multiplying digital-to-analog converter (DAC) is designed to operate from a single 2.7V to 5.5V supply.
The applied external reference input voltage VREF determines the full-scale output current. An internal feedback resistor (RFB) provides temperature tracking for the full-scale output when combined with an external, current-to-voltage (I/V) precision amplifier.
A RSTSEL pin allows system reset assertion (RS) to force all registers to zero code when RSTSEL = '0', or to mid-scale code when RSTSEL = '1'. Additionally, an internal power-on reset forces all registers to zero or mid-scale code at power-up, depending on the state of the RSTSEL pin.
A parallel interface offers high-speed communications. The DAC8805 is packaged in a space-saving TSSOP-38 package and has an industry-standard pinout. The device is specified from -40°C to +125°C.
For a 16-bit, pin-compatible version, see the DAC8822.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
