--- 产品详情 ---
Function | Serializer |
Color depth (bpp) | 24 |
Input compatibility | LVDS |
Pixel clock frequency (Max) (MHz) | 68 |
Output compatibility | FPD-Link LVDS |
Features | Low-EMI Point-to-Point Communication |
Operating temperature range (C) | -10 to 70 |
- No Special Start-up Sequence Required Between Clock/Data and /PD Pins. Input Signal (Clock and Data) Can be Applied Either Before or After the Device is Powered.
- Support Spread Spectrum Clocking Up to 100KHz Frequency Modulation & Deviations of ±2.5% Center Spread or ?5% Down Spread.
- "Input Clock Detection" Feature Will Pull All LVDS Pairs to Logic Low when Input Clock is Missing and When /PD Pin is Logic High.
- 18 to 68 MHz Shift Clock Support
- Best–in–Class Set & Hold Times on TxINPUTs
- Tx Power Consumption < 130 mW (typ) @65MHz Grayscale
- 40% Less Power Dissipation Than BiCMOS Alternatives
- Tx Power-down Mode < 60μW (typ)
- Supports VGA, SVGA, XGA and Dual Pixel SXGA.
- Narrow Cus Reduces Cable Size and Cost
- Up to 1.8 Gbps Throughput
- Up to 227 Megabytes/sec Bandwidth
- 345 mV (typ) Swing LVDS Devices for Low EMI
- PLL Requires No External Components
- Compatible with TIA/EIA-644 LVDS Standard
- Low Profile 56-Lead TSSOP Package
- Improved Replacement for:
- SN75LVDS83, DS90CF383A
All trademarks are the property of their respective owners. TRI-STATE is a trademark of Texas Instruments. TRI-STATE is a trademark of Texas Instruments.
The DS90CF383B transmitter converts 28 bits of CMOS/TTL data into four LVDS (Low Voltage Differential Signaling) data streams. A phase-locked transmit clock is transmitted in parallel with the data streams over a fifth LVDS link. Every cycle of the transmit clock 28 bits of input data are sampled and transmitted. At a transmit clock frequency of 65 MHz, 24 bits of RGB data and 3 bits of LCD timing and control data (FPLINE, FPFRAME, DRDY) are transmitted at a rate of 455 Mbps per LVDS data channel. Using a 65 MHz clock, the data throughput is 227 Mbytes/sec. The DS90CF383B is fixed as a Falling edge strobe transmitter and will interoperate with a Falling edge strobe Receiver (DS90CF386) without any translation logic.
This chipset is an ideal means to solve EMI and cable size problems associated with wide, high speed TTL interfaces.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
