--- 产品详情 ---
具有 +/-9V 输出和 +/-15kV IEC-ESD 保护的 5V 双通道 120kbps RS-232 线路驱动器/接收器
Drivers per package | 2 |
Receivers per package | 2 |
Logic voltage (Min) (V) | 5 |
Data rate (Max) (kbps) | 120 |
Main supply voltage (Nom) (V) | 5 |
ESD HBM (kV) | 15 |
Rating | Catalog |
Operating temperature range (C) | -40 to 85, 0 to 70 |
Vout (Typ) (V) | 9 |
- IEC61000-4-2 (Level 4) ESD Protection for RS-232 Bus Pins:
- ±8-kV Contact Discharge
- ±15-k-V Air-Gap Discharge
- ±15-kV Human-Body Model
- Meets or Exceeds the Requirements of TIA/EIA-232-F and ITU v.28 Standards
- Operates at 5-V VCC Supply
- Operates Up to 120 kbit/s
- External Capacitors: 4 × 0.1 μF or 4 × 1 μF
- Latch-Up Performance Exceeds 100 mA Per JESD 78, Class II
The TRS202E device consists of two line drivers, two line receivers, and a dual charge-pump circuit. TRS202E has IEC61000-4-2 (Level 4) ESD protection pin-to-pin (serial-port connection pins, including GND). The device meets the requirements of TIA/EIA-232-F and provides the electrical interface between an asynchronous communication controller and the serial-port connector. The charge pump and four small external capacitors allow operation from a single 5-V supply. The device operates at data signaling rates up to 120 kbit/s and a maximum of
30-V/μs driver output slew rate.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
