--- 产品详情 ---
Number of receivers | 4 |
Number of transmitters | 0 |
Duplex | Half |
Supply voltage (Nom) (V) | 5 |
Signaling rate (Max) (Mbps) | 30 |
IEC 61000-4-2 contact (+/- kV) | None |
Fault protection (V) | -14 to 14 |
Common mode range | -14 to 14 |
Number of nodes | 32 |
Isolated | No |
ICC (Max) (mA) | 23 |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
- CMOS Design for Low Power
- ±0.2V Sensitivity Over the Input Common Mode Voltage Range
- Typical Propagation Delays: 19 ns
- Typical Input Hysteresis: 60 mV
- Inputs Won't Load Line when VCC = 0V
- Meets the Requirements of EIA Standard RS-422
- TRI-STATE Outputs for System Bus Compatibility
- Available in Surface Mount
- Open Input Failsafe Feature, Output High for Open Input
All trademarks are the property of their respective owners.
The DS34C86T is a quad differential line receiver designed to meet the RS-422, RS-423, and Federal Standards 1020 and 1030 for balanced and unbalanced digital data transmission, while retaining the low power characteristics of CMOS.
The DS34C86T has an input sensitivity of 200 mV over the common mode input voltage range of ±7V. Hysteresis is provided to improve noise margin and discourage output instability for slowly changing input waveforms.
The DS34C86T features internal pull-up and pull-down resistors which prevent output oscillation on unused channels.
Separate enable pins allow independent control of receiver pairs. The TRI-STATE outputs have 6 mA source and sink capability. The DS34C86T is pin compatible with the DS3486.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
