--- 产品详情 ---
USB 2.0-eUSB2 双路中继器
Type | Redriver |
Function | USB2 |
USB speed (Mbps) | 480 |
Number of channels (#) | 2 |
Supply voltage (Max) (V) | 1.98, 3.6 |
Supply voltage (Min) (V) | 1.62, 3 |
Input/ouput voltage (Min) (V) | 0 |
Input/ouput voltage (Max) (V) | 3.6 |
Configuration | Dual-channel |
Features | implementation of USB 2.0 and eUSB2 compliance port Support for Low-speed (LS), Full-speed (FS), High-speed (HS) signals |
Rating | Catalog |
Operating temperature range (C) | -20 to 85 |
ESD HBM (Typ) (kV) | 1.5 |
Bandwidth (MHz) | 240 |
- Compliance to USB 2.0 and eUSB2 (rev 1.1)
- Support for Low-speed (LS), Full-speed (FS), High-speed (HS)
- Dual repeater with 2:2 crossbar Mux
- Host and device mode (DRD) support
- 4 eUSB2 compensation settings to meet different system requirements
- eUSB2 LS/FS signaling meets 1.2 V option of the eUSB2 interface
TUSB2E22 enables implementation of USB 2.0 compliance port on newer processors using lower voltage processes.
TUSB2E22 is a USB-Compliant eUSB2-USB 2.0 repeater supporting both device and host modes.
TUSB2E22 supports USB Low-speed (LS) and Full-speed (FS) signals and High-speed (HS) signals.
TUSB2E22 is designed to interface with eUSB2 eDSPr or eUSPr operating at 1.2 V single-ended signaling.
TUSB2E22 has 4 levels of compensation settings via EQ0 and EQ1 pins. These settings could be used to optimize compensation for different eUSB2 channel loss profiles.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
