--- 产品详情 ---
具有集电极开路输出的军用 4 通道、2 输入、4.5V 至 5.5V 双极与非门
Technology Family | S |
Supply voltage (Min) (V) | 4.5 |
Supply voltage (Max) (V) | 5.5 |
Number of channels (#) | 4 |
Inputs per channel | 2 |
IOL (Max) (mA) | 20 |
IOH (Max) (mA) | -1 |
Input type | Bipolar |
Output type | Open-Collector |
Features | High speed (tpd 10- 50ns) |
Data rate (Max) (Mbps) | 40 |
Rating | Military |
- Package Options Include Plastic “Small Outline" Packages, Ceramic Chip Carriers and Flat Packages, and Plastic and Ceramic DIPs
- Dependable Texas Instruments Quality and Reliability
These devices contain four independent 2-input-NAND gates. The open-collector outputs require pull-up resistors to perform correctly. They may be connected to other open-collector outputs to implement active-low wired-OR or active-high wired-AND functions. Open-collector devices are often used to generate higher VOH levels.
The SN5403, SN54LS03 and SN54S03 are characterized for operation over the full military temperature range of -55°C to 125°C. The SN7403, SN74LS03 and SN74S03 are characterized for operation from 0°C to 70°C.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
