--- 产品详情 ---
DSP | 2 C66x |
DSP MHz (Max) | 500 |
Operating system | Android, Linux, RTOS |
Ethernet MAC | 1000, 2-port 1Gb switch |
PCIe | 2 PCIe Gen2 |
TI functional safety category | Functional Safety-Compliant |
Rating | Automotive |
Operating temperature range (C) | -40 to 125 |
DRA78x 处理器采用 367 焊球、15mm×15mm、0.65mm 焊球间距(0.8mm 间距规则可用于信号)(通过 Channel? 阵列 (VCA) 技术实现)、球栅阵列 (FCBGA) 封装。
此架构旨在昨用经济高效的解决方案,为汽车协处理、混合无线电和放大器应用提供高性能并发性 , 实现 DRA75x(“Jacinto 6 EP”和“Jacinto 6 Ex”)、DRA74x“Jacinto 6”、DRA72x“Jacinto 6 Eco”和 DRA71x“Jacinto 6 Entry”信息娱乐处理器系列的全面可扩展性。
此外,德州仪器 (TI) 提供一整套针对 Arm 和 DSP 的开发工具,其中包括 C 语言编译器和一个实现源代码执行可视化的调试接口。
DRA78x Jacinto 6 RSP(无线电音频处理器)系列器件符合 AEC-Q100 标准。
该器件 采用 简化的电源轨映射,这使得低成本电源管理集成电路 (PMIC) 解决方案得以实现。
The DRA78x processor is offered in a 367-ball, 15×15-mm, 0.65-mm ball pitch (0.8mm spacing rules can be used on signals) with Via Channel? Array (VCA) technology, ball grid array (S-PBGA) package.
The architecture is designed to deliver high-performance concurrencies for automotive co-processor, hybrid radio and amplifier applications in a cost-effective solution, providing full scalability from the DRA75x ("Jacinto 6 EP" and "Jacinto 6 Ex"), DRA74x "Jacinto 6", DRA72x "Jacinto 6 Eco", and DRA71x "Jacinto 6 Entry" family of infotainment processors, including voice, HMI, multimedia and smartphone projection mode capabilities.
Additionally, TI provides a complete set of development tools for the Arm, and DSP, including C compilers and a debugging interface for visibility into source code execution.
The DRA78x Jacinto 6 RSP (Radio Sound Processor) device family is qualified according to the AEC-Q100 standard.
The device features a simplified power supply rail mapping which enables lower cost PMIC solutions.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
