--- 产品详情 ---
适用于 12V、24V 或 48V 应用的含传感器单相 BLDC 栅极驱动器
Rating | Catalog |
Architecture | Gate driver |
Control topology | Sensored, Trapezoidal |
Control interface | 1xPWM |
Vs (Min) (V) | 6 |
Vs ABS (Max) (V) | 18 |
- Predriver for Single-Phase Full-Wave Drive
- PNP-NMOS is Used as an External Power TR,
Enabling High-Efficiency Low-Consumption
Drive by Means of the Low-Saturation Output
and Single-Phase Full-Wave Drive (PMOS-
NMOS Also Applicable)
- External PWM Input Enabling Variable Speed
Control- Separately-Excited Upper Direct PWM (f = 25
kHz) Control Method, Enabling Highly Silent
Speed Control
- Compatible with 12-V, 24-V, and 48-V Power
Supplies - Current Limiter Circuit Incorporated
- Chopper Type Current Limit at Start
- Reactive Current Cut Circuit Incorporated
- Reactive Current Before Phase Change is Cut
to Enable Silent and Low-Consumption Drive
- Minimum Speed Setting Pin
- Minimum Speed Can Be Set With External
Resistor. Start Assistance Circuit Enables Start
at Extremely Low Speed.
- Constant-Voltage Output Pin for Hall Bias
- Lock Protection and Automatic Reset Functions
Incorporated - FG (Rotation Speed Detection) and RD (Lock
Detection) Output
The TMP814 is a single-phase bipolar variable speed fan motor predriver that works with an external PWM signal. A highly efficient, quiet and low-power consumption motor driver circuit, with a large variable speed, can be implemented by adding a small number of external components.
This device is optimal for driving large scale fan motors (with large air volume and large current) such as those used in servers and consumer products.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
