--- 产品详情 ---
Topology | Boost, Flyback, Forward, Full-Bridge, Half-Bridge, Push-Pull |
Duty cycle (Max) (%) | 50 |
Vin (Max) (V) | 40 |
UVLO thresholds on/off (V) | 7.7/7 |
Features | Error Amplifier, Multi-topology, Soft Start, Synchronization Pin |
Operating temperature range (C) | -40 to 125 |
Switching frequency (Max) (kHz) | 1000 |
Rating | Automotive |
Gate drive (Typ) (A) | 1.5 |
- Qualified for Automotive Applications
- Pin-for-Pin Compatible With the UC2846
- 65-ns Typical Delay From Shutdown to Outputs and
50-ns Typical Delay From Sync to Outputs - Improved Current Sense Amplifier With Reduced Noise Sensitivity
- Differential Current Sense With 3-V Common-Mode Range
- Trimmed Oscillator Discharge Current for Accurate Deadband Control
- Accurate 1-V Shutdown Threshold
- High Current Dual Totem Pole Outputs (1.5-APeak)
- TTL Compatible Oscillator SYNC Pin Thresholds
- ESD Protection
- 4-kV Human-Body Model (HBM)
- 500-V Charged-Device Model (CDM)
The UC2856 is a high performance version of the popular UC2846 series of current mode controllers, and is intended for both design upgrades and new applications where speed and accuracy are important. All input to output delays have been minimized, and the current sense output is slew rate limited to reduce noise sensitivity. Fast 1.5-A peak output stages have been added to allow rapid switching of power FETs.
A low impedance TTL compatible sync output has been implemented with a 3-state function when used as a sync input.
Internal chip grounding has been improved to minimize internal noise caused when driving large capacitive loads. This, in conjunction with the improved differential current-sense amplifier, results in enhanced noise immunity.
Other features include a trimmed oscillator current (8%) for accurate frequency and dead-time control, a 1-V 5% shutdown threshold, and 4-kV minimum ESD protection (HBM) on all pins.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
