--- 产品详情 ---
Number of series cells | 1, 2, 3 |
Charge current (Max) (A) | 2.5 |
Operating Vin (Max) (V) | 17 |
Cell chemistry | Li-Ion/Li-Polymer |
Battery charge voltage (Min) (V) | 4.2, 8.4, 12.6 |
Battery charge voltage (Max) (V) | 4.2, 8.4, 12.6 |
Absolute Vin (safety rating) (Max) ((V)) | 20 |
Control interface | Standalone (RC-Settable) |
Features | BAT temp thermistor monitoring (hot/cold profile), IC thermal regulation, IINDPM (Input current limit), Input OVP, Power Path |
Operating Vin (Min) (V) | 4.5 |
Rating | Catalog |
- 1.6-MHz Synchronous switched-mode charger with 2.5-A integrated N-MOSFETs
- Up to 92% efficiency
- 30-V Input rating with adjustable overvoltage protection
- 4.5-V to 17-V Input operating voltage
- Battery charge voltage
- 1-Cell, 2-cell, or 3-cell with 4.2 V/cell
- High integration
- Automatic Power Path selector between adapter and battery
- Dynamic power management
- Integrated 20-V switching MOSFETs
- Integrated bootstrap diode
- Internal digital soft start
- Safety
- Thermal regulation loop throttles back current to limit TJ = 120°C
- Thermal shutdown
- Battery thermistor sense hot/cold charge suspend and battery detect
- Adjustable input overvoltage protection
- Cycle-by-cycle current limit
- Accuracy
- ±0.5% Charge voltage regulation
- ±5% Charge current regulation
- ±6% Input current regulation
- <15-μA Battery current with adapter removed
- <1.5-mA Input current with adapter present and charge disabled package
The BQ24133 device is a highly integrated stand-alone Li-Ion and Li-Polymer switched-mode battery charger with two integrated N-channel power MOSFETs. The device offers a constant-frequency synchronous PWM controller with high accuracy regulation of input current, charge current, and voltage. The BQ24133 closely monitors the battery pack temperature to allow charge only in a preset temperature window. The BQ24133 charges one, two, or three cells (selected by CELL pin) at a fixed 4.2 V/cell.
The BQ24133 charges the battery in three phases: preconditioning, constant current, and constant voltage.
The BQ24133 provides power path selector gate driver ACDRV/CMSRC on input NMOS pair ACFET (Q1) and RBFET (Q2), and BATDRV on a battery PMOS device (Q3). When the qualified adapter is present, the system is directly connected to the adapter. Otherwise, the system is connected to the battery. In addition, the power path prevents battery from boosting back to the input.
The BQ24133 charges the battery from a DC source as high as 17 V, including a car battery. The input overvoltage limit is adjustable through the OVPSET pin. The AVCC, ACP, and ACN pins have a 30-V rating. When a high-voltage DC source is inserted, Q1 and Q2 remain off to avoid high-voltage damage to the system.
For 1-cell applications where the battery is not removable, the system can be directly connected to the battery to simplify the power path design and reduce the cost. With this configuration, the battery can automatically supplement the system load if the adapter is overloaded.
The BQ24133 is available in a 24-pin, 5.5-mm × 3.5-mm thin VQFN package.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
