--- 产品详情 ---
Number of series cells | 2, 3, 4 |
Charge current (Max) (A) | 8 |
Operating Vin (Max) (V) | 24 |
Cell chemistry | Li-Ion/Li-Polymer |
Battery charge voltage (Min) (V) | 1.024 |
Battery charge voltage (Max) (V) | 19.2 |
Absolute Vin (safety rating) (Max) ((V)) | 30 |
Control interface | SMBus |
Features | Input OVP, Power Path |
Operating Vin (Min) (V) | 0 |
Rating | Catalog |
- SMBus Host-Controlled NMOS-NMOS Synchronous Buck Converter with
Programmable 615kHz, 750kHz, and 885kHz Switching Frequencies - Automatic N-channel MOSFET Selection of System Power Source from
Adapter or Battery Driven by Internal Charge Pumps - Enhanced Safety Features for Over Voltage Protection, Over Current
Protection, Battery, Inductor and MOSFET Short Circuit Protection - Programmable Input Current, Charge Voltage, Charge Current Limits
- ±0.5% Charge Voltage Accuracy up to 19.2V
- ±3% Charge Current Accuracy up to 8.128A
- ±3% Input Current Accuracy up to 8.064A
- ±2% 20x Adapter Current or Charge Current Amplifier
Output Accuracy
- Programmable Battery Depletion Threshold, and Battery LERAN Function
- Programmable Adapter Detection and Indicator
- Integrated Soft Start
- Integrated Loop Compensation
- Real Time System Control on ILIM pin to Limit Charge Current
- AC Adapter Operating Range 9V-24V
- 5μA Off-State Battery Discharge Current
- 20-pin 3.5 × 3.5 mm2 QFN Package
- APPLICATIONS
- Portable Notebook Computers, UMPC, Ultra-Thin Notebook, and Netbook
- Personal Digital Assistant
- Handheld Terminal
- Industrial and Medical Equipment
- Portable Equipment
PowerPAD is a trademark of Texas Instruments.
The bq24725 is a high-efficiency, synchronous battery charger, offering low component count for space-constraint, multi-chemistry battery charging applications.
The bq24725 uses two charge pumps to separately drive n-channel MOSFETs (ACFET, RBFET and BATFET) for automatic system power source selection.
SMBus controlled input current, charge current, and charge voltage DACs allow for high regulation accuracies that can be programmed by the system power management micro-controller.
The bq24725 uses internal input current register or external ILIM pin to throttle down PWM modulation to reduce the charge current.
The bq24725 charges two, three or four series Li+ cells, and is available in a 20-pin, 3.5 × 3.5 mm2 QFN package.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
