--- 产品详情 ---
Vin (Min) (V) | 3 |
Vin (Max) (V) | 36 |
Vout (Min) (V) | 1 |
Vout (Max) (V) | 34 |
Iout (Max) (A) | 6 |
Iq (Typ) (uA) | 7 |
Switching frequency (Min) (kHz) | 200 |
EMI features | Integrated capacitors, Low parasitic Hotrod packaging, Spread spectrum |
Switching frequency (Max) (kHz) | 2200 |
Features | Enable, Forced PWM, Frequency Synchronization, Light Load Efficiency, Over Current Protection, Power Good, Soft Start Fixed, Spread Spectrum, Synchronous Rectification, Wettable Flanks Package |
Rating | Automotive |
Regulated outputs (#) | 1 |
Control mode | Current Mode |
Duty cycle (Max) (%) | 98 |
- AEC-Q100 qualified for automotive applications
- Temperature grade 1: –40°C to +150°C, TJ
- Functional Safety-Capable
- Documentation available to aid functional safety system design
- Optimized for ultra-low EMI requirements
- Meets CISPR25 class 5 standard
- Hotrod? package minimizes switch node ringing
- Internal bypass capacitors reduce EMI
- Parallel input path minimizes parasitic inductance
- Spread spectrum reduces peak emissions
- Adjustable switch node rise time
- Designed for rugged automotive applications
- Supports 42-V load dump
- 0.4-V dropout with 4-A load (typical)
- High efficiency power conversion at all loads
- 7-μA no load current at 13.5 VIN, 3.3 VOUT
- 90% PFM efficiency at 1-mA, 13.5 VIN, 5 VOUT
- External bias option for improved efficiency
- Pin compatible with:
- LM61460-Q1 (36 V, 6A)
The LMQ61460-Q1 is a high-performance, DC-DC synchronous buck converter with integrated bypass capacitors. With integrated high-side and low-side MOSFETs, up to 6 A of output current is delivered over a wide input range of 3.0 V to 36 V; 42-V tolerance supports load dump for durations of 400 ms. The device implements soft recovery from dropout eliminating overshoot on the output.
The device is specifically designed for minimal EMI. The device incorporates pseudo-random spread spectrum, integrated bypass capacitors, adjustable SW node rise time, low-EMI VQFN-HR package featuring low switch node ringing, and optimized pinout for ease of use. The switching frequency can be synchronized between 200 kHz and 2.2 MHz to avoid noise sensitive frequency bands. In addition the frequency can be selected for improved efficiency at low operating frequency or smaller solution size at high operating frequency.
Auto-mode enables frequency foldback when operating at light loads, allowing an unloaded current consumption of only 7 μA (typical) and high light load efficiency. Seamless transition between PWM and PFM modes, along with very low MOSFET ON resistances and an external bias input, ensures exceptional efficiency across the entire load range.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
