--- 产品详情 ---
Vin (Min) (V) | 3 |
Vin (Max) (V) | 28 |
Vout (Min) (V) | 0.3 |
Vout (Max) (V) | 1.5 |
Iout (Max) (A) | 60 |
Iq (Typ) (uA) | 1800 |
Switching frequency (Min) (kHz) | 200 |
Switching frequency (Max) (kHz) | 500 |
Features | Power Good |
Regulated outputs (#) | 1 |
Number of phases | 1+1 |
Rating | Catalog |
- 3-V to 28-V Conversion Voltage Range
- Minimal External Parts Count
- Full IMVP-6.5 Compliance, Including VR_TT and Output Current Monitor
- Supports 7-Bit VID Code for CPU and GPU
- 0.3-V to 1.5-V Output Voltage Range
- 0.5% VCORE Accuracy Over Line/Load/Temp
- Optimized Efficiency at Light and Heavy Loads
- Patented Output Overshoot Reduction Reduces Output Capacitance
- Adjustable Voltage Positioning
- Selectable 250/300/350/500 kHz Frequency
- 8-Level Selectable Current Limit
- Gate Drivers with 2-A Driving Capability w/Integrated Boost Diode
- Available in 5 mm × 5 mm, 32-Pin QFN PowerPAD Package
- APPLICATIONS
- IMVP-6.5 Single-Phase CPU and Graphics (Render) VCORE Applications
The TPS51611 is a fully IMVP-6.5 compliant single-phase synchronous buck controller with integrated gate drivers. Advanced control features such as D-CAP+? architecture and OSR overshoot reduction provide fast transient response, lowest output capacitance and high efficiency. The TPS51611 supports both the Intel mobile CPU and integrated graphics modes with the integrated 7-bit DAC in Calpella platform. The TPS51611 provides the full complement of IMVP-6.5 I/O including VR_TT, DPRSLPVR, and IMON. Adjustable control of VCORE slew rate and voltage positioning round out the IMVP-6.5 features. In addition, the TPS51611 includes two high-current MOSFET gate drivers to drive external FETs with low switching loss. The TPS51611 is available in the 5 mm × 5 mm, 32-pin QFN and is rated to operate from –10°C to 105°C
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
