--- 产品详情 ---
Vin (Min) (V) | 2.97 |
Vin (Max) (V) | 48 |
Vout (Min) (V) | 1.26 |
Vout (Max) (V) | 500 |
Regulated outputs (#) | 1 |
Switching frequency (Min) (kHz) | 100 |
Switching frequency (Max) (kHz) | 1000 |
Iq (Typ) (mA) | 3.7 |
Features | Adjustable Current Limit, Enable, Frequency Synchronization, Light Load Efficiency, Pre-Bias Start-Up, UVLO Adjustable |
Duty cycle (Max) (%) | 85 |
Rating | Automotive |
- LM3481QMM are Automotive-Grade Products
That are AEC-Q100 Grade 1 Qualified (–40°C to
+125°C Operating Junction Temperature) - 10-Lead VSSOP Package
- Internal Push-Pull Driver With 1-A Peak Current
Capability - Current Limit and Thermal Shutdown
- Frequency Compensation Optimized With a Capacitor
and a Resistor - Internal Softstart
- Current Mode Operation
- Adjustable Undervoltage Lockout With Hysteresis
- Pulse Skipping at Light Loads
- Key Specifications
- Wide Supply Voltage Range of 2.97 V to 48 V
- 100-kHz to 1-MHz Adjustable and Synchronizable
Clock Frequency - ±1.5% (Over Temperature) Internal
Reference - 10-μA Shutdown Current (Over Temperature)
The LM3481 device is a versatile Low-Side N-FET high-performance controller for switching regulators. The device is suitable for use in topologies requiring a low-side FET, such as boost, flyback, SEPIC, and so on. The LM3481 device can be operated at extremely high switching frequencies to reduce the overall solution size. The switching frequency of the LM3481 device can be adjusted to any value between 100kHz and 1MHz by using a single external resistor or by synchronizing it to an external clock. Current mode control provides superior bandwidth and transient response in addition to cycle-by-cycle current limiting. Current limit can be programmed with a single external resistor.
The LM3481 device has built-in protection features such as thermal shutdown, short-circuit protection and overvoltage protection. Power-saving shutdown mode reduces the total supply current to 5 μA and allows power supply sequencing. Internal soft-start limits the inrush current at start-up.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
